APS Twin Turbo install finished
Picked up the car yesterday.
475 rwhp and just above 500 rwtq. This is at slightly under 5.5 psi with no adjustments to torque management. Yeah, could of had more, but Google Harry Reasoner and helicopter pilot and you'll better understand why I'm very happy with the tune
More boost and some torque management tweaking will have to wait on when a better transmission and diff/with brace go under it (hopefully this winter or early spring)
Impressions?
Starts, idles at 500 rpm with the air conditioning on, and drives like stock without any hint of the devil hiding under the thottle pedal. It is a little louder without the cats. Press the pedal down and ...HOLY &#*%
Didn't have too much opportunity to get on it on the way home (police were out in force on I-75, I-10 and hwy 231) but it is a completely different animal when the throttle is floored.
With a temperature of between 94 and 97 and stifling Florida humidity, oil pressure was 37-38 psi with temp varying between 218-223 degrees at 75 mph cruise. Water temp varied between 196 and 198 during the trip home with a few peaks of approximately 204 degrees in stop and go traffic.
A big
to Mike Norris, Tom Porter, Jeff, and the rest of the Next Level Performance crew for an install that looks like it came from the factory and for making me feel at home while I was there.
http://forums.corvetteforum.com/show....php?t=1471957
Mine ended up being 6 days, but I'm sure that depends on whatever shop doing the install has going on.
Yes Z06 wheels and brakes. The wheels are stock Z06 offset so no need for spacers. The car is lowered - all the way down on stock bolts in the rear and somewhat down (but not full travel of the stock bolts) in the front. I do need to raise it just a little bit in the front as the rubber air dam scrapes quite a bit.
Yes it is insane...insanely fun
BUT when I put the pedal down the CAR IS GONE!!! and love the sound of WISSH between gear changes
Enjoy your ride.
Enjoy your ride.
Maybe just before the new Camaro comes out I'll give it a shot. Until then I need a car to drive and I'm not in any hurry to install another block.
Glad all is well and thansk for the props.
Fred,
We can run more b oost, but the trick is keeping her off the rev limiter
Have a good one all.
Mike Norris
Cajun
Cajun
Some thoughts:
Its probably important to point out that the use of much lower boost (and therefore lower final numbers) then APS provides for was by my choice. The combination certainly has room to grow as other people on the board have shown.
The APS kit is a first class piece of work. The finished installation looks like it rolled off the line at Bowling Green that way. That's not to say that Magnuson's/A&A's kits/ECS's/etc. kits look cobbled together. Far from it. For me it was a tough choice as to what system to get, I just decided that this was the way I wanted to go, and as you've pointed out, been very happy with NLP and APS.
The car behaves just like it was stock until you press down on the accelerator. While a heads/cam/headers/intake car could generate similar rwhp numbers (I believe the torque would be a little less) it would be a little harder to live with - especially with a stock converter.
We should all be very glad that we have a large number of options available to satisfy our addiction
Cajun
Not a lot of money at all if you consider that for the money he spent, he has a setup that can produce 1000 HP, ...he is running what is deemed "safe" for his stock motor/ transmission, etc.
It's hands down the most potential for the $$$.
