6.2 in 2008
Old Sep 8, 2006 | 06:44 PM
hhntr111's Avatar
hhntr111
Default 6.2 in 2008
Is there anything to a rumor that there will be a 6.2 liter LS3 in 2008?
Old Sep 8, 2006 | 06:55 PM
AU N EGL's Avatar
AU N EGL
the 6.2 L is called the L92 not the LS3 and it will be in the 2007 CADILLAC ESCALADE The L92 motor is avaible now from SDPC.
http://media.gm.com/us/cadillac/en/p...ifications.htm
Type:
6200 6.2L V-8 (L92)
Displacement (cu in / cc):
378 / 6199
Bore & stroke (in / mm):
4.06 x 3.62 / 103.25 x 92
Block material:
cast aluminum
Cylinder head material:
cast aluminum
Valvetrain:
OHV, 2 valves per cylinder
Ignition system:
coil near plug ignition, iridium electrode tip/ iridium core spark plugs, low-resistance spark plug wires
Fuel delivery:
sequential fuel injection
Compression ratio:
10.5:1
Horsepower (hp / kw @ rpm):
403 / 301 @ 5700*
Torque (lb-ft / Nm @ rpm):
417 / 565 @ 4400*
Recommended fuel:
premium recommended but not required
Maximum engine speed (rpm):
5900
Photo:
http://gm.wieck.com/forms/gm/previewpage?026545
More L82 info:
http://ls1tech.com/forums/showthread.php?t=499059
In short, Not likely put into the vette.
Old Sep 9, 2006 | 05:37 AM
shopdog's Avatar
shopdog
The LS3, a slightly warmed over L92 with a reported 425 hp, is almost certain to be the base engine in the 2008. With the cessation of LS2 production at the end of the 2007 model year, what else does Chevy have to put in the Corvette?
Also look for a supercharged version of the same engine, to be called the LS9, that's reported to make over 600 hp, in the upcoming "super Vette".
Old Sep 9, 2006 | 07:28 AM
niphilli2's Avatar
niphilli2
I knew it would only be a matter of time. Why would you put your best technology heads on a truck motor and not on the vette.
This is awesome news for folkes that just want to do a cam swap and some LT headers. It will be easy to make 450-500 RWHP with LTs and a cam with the L92 heads!
Old Sep 9, 2006 | 07:37 AM
hhntr111's Avatar
hhntr111
Great news, and thanks. Nice to look forward to.
To 6.2 in 2008
