Fuel fill problems
Old Sep 9, 2006 | 12:02 PM
hemmerman's Avatar
hemmerman
Default Fuel fill problems
I have a C6Z. Love it! My third Vette. Never had this issue with the others. Nor did I have the problem with this car until it went to the GM dealership for the new roof recall. My difficulty recenty has been, I'll start to fill up, Always fill up. And the pump noozle will kick off before the tank is full. I have always stopped fueling as soon as it kicks off the first time. And the first time this happened that's what I did. Left the station and drove way with less than a full tank. Didn't think much about it at first. Thought it strange but, maybe just the pump at that station. Now it's getting to me. Doesn't matter where I stop for gas same thing. Start fuelling and bang kicks out. Try it slower, no, still kicks out. The last time I filled up it took me 10-20 trys to get the tank full.
Anyone out there with the same problem. A fix, ideas or posible solution?
Old Sep 9, 2006 | 12:15 PM
C6 MoneyPit's Avatar
C6 MoneyPit
St. Jude Donor '06-'07-'10, '15. '22-'23
I have the same problem from time to time. Check out this thread, lot's of ideas and suggestions about this...
http://forums.corvetteforum.com/show...+off+c6+nozzle
Old Sep 9, 2006 | 04:41 PM
beaversstonehaven's Avatar
beaversstonehaven
This happened to me a few weeks ago. Has not happen since. I think it was a problem with the pump in my case.
Old Sep 9, 2006 | 05:39 PM
Wayne88's Avatar
Wayne88
It happens to me also.
I twist the nozzle upward and hold it untill full.
Old Sep 9, 2006 | 06:41 PM
LS WON's Avatar
LS WON
After first click I can usually add up to one gallon more of gas to the point the gasoline is at top of filler coming out.
Old Sep 9, 2006 | 09:17 PM
Irv's Avatar
Irv
Try withdrawing the nozzle from the fuel neck about 1/4-1/2 inch. This usually stops premature shut-off.
Old Sep 9, 2006 | 09:47 PM
MADinAK's Avatar
MADinAK
St. Jude Donor '06-'07-'08-'09-'10,'14
Originally Posted by Irv
Try withdrawing the nozzle from the fuel neck about 1/4-1/2 inch. This using stops premature shut-off.
Did you have to say premature?
I've had the opposite effect when filling my 07. I stuffed in the nozzle as far as it would go. It clicked off and I tried to add another .30 cents or so to get to an even dollar. After another nickle or so the gas was up into the neck and nearly ran over.
Old Sep 10, 2006 | 06:06 PM
rwpatte's Avatar
rwpatte
There is a service bulletin on a fix for the problem. My ZO did the same thing. I went to the dealer and was told the part was on B/O. I haven't heard a thing for Three months. The problem stopped. So I'm not bugging the dealer.
Old Sep 10, 2006 | 11:01 PM
StuSegal's Avatar
StuSegal
47 yrs of Vettes
Default Have you ever seen this?
I have had this problem occasionally, on a couple different cars. I always thought it had something to do with the specific gas pump nozzle that was being used and the shutoff mechanism in the nozzle.
The other day I saw something unusual though (and be advised, I live in a state with a restriction against pumping your own fuel, so it's always pumped by gas station attendants) - - I had almost no fuel, the pump clicked off after putting in only about 5 gallons, and I advised the attendant that it was nowhere near full, and he did something I had never seen before. He spun the nozzle 180 degrees, so it was "upside down" (not really, as it was still in the filler neck, but it was reversed from the normal position), then he squeezed the trigger and set the clip, and it filled all the way and clicked off at the appropriate time!
In 40 years of driving I've never seen anyone do this. Have you?
Old Sep 11, 2006 | 08:32 AM
hemmerman's Avatar
hemmerman
Default Thanks
Thanks for your ideas. I have a couple posible solutions to try. And maybe take it back to the dealership.
Old Sep 11, 2006 | 10:27 AM
dollarbill's Avatar
dollarbill
St. Jude Donor '06-'07-'08-'09-'10-'11
This worked for me!
To Fuel fill problems
