C6A6 rearend ratio?
Nothing wrong with the 2.56, but I drag race a lot and I just want a little more grrrr out of the hole.
If the A6 (with 2.56s) is truly the equivalant to having an A4 with 3.90s then there would never be any need to upgrade the gears in a modified higher rev situation such as an aggressive heads and cam package, just a converter swap and go, is that possible?
If the A6 (with 2.56s) is truly the equivalant to having an A4 with 3.90s then there would never be any need to upgrade the gears in a modified higher rev situation such as an aggressive heads and cam package, just a converter swap and go, is that possible?I think where most people get confused is that most A4's with stiffer gears ALSO have a 3200 to 3600 stall converter. That is worth at least .2 to .3 in the quarter. That's the only reason they would spank the A6.
So I respectfully disagree.
OK, we can disagree. However, I'd love to hear the reasons. I'll give you one that might be true: The A4 is lighter than the A6. Spank? Well, no, but it would probably win based on lower weight if it had the 3.90's.
I find it interesting that people who have the A4 are always trying to figure out why it's better than the A6. Probably because they are pissed that they didn't get the A6. Don't get me wrong. If I had an A4, I'd be pissed and trying to figure out why it was really better than the A6.
Other than weight, the A6 is a great tranny. It gives you a tranny that has great low gears, but it gives you that 6th gear like the manual. I can drive at 70 mph at only 1500 rpm.
You could be right about the TM. Maybe it is so high with the A6 due to the lower gear. Might be the reason it is set this way.
Here's the gear chart:
..GEAR......Mode..or..Option
............Z06...Std_6-spd...Z51_6-spd...6-spd_Auto...4-spd_Auto
..1st.......2.66....2.66........2.97.... .....4.02........3.06
..2nd.......1.78....1.78........2.07.... .....2.36........1.63
..3rd.......1.30....1.30........1.43.... .....1.53........1.00
..4th.......1.00....1.00........1.00.... .....1.15........0.70
..5th.......0.74....0.74........0.71.... .....0.85
..6th.......0.50....0.50........0.57.... .....0.67
Reverse.....2.90....2.90........3.28.... .....3.06........2.29
Axle Ratio..3.42....3.42........3.42......... 2.56.....2.73(or_3.15)
So A6 1,2,3 = 10.29, 6.04, 3.92
A4 1,2,3 with 3.90's = 11.93, 6.36, 3.90
So you are absolutely correct, the A4 with 3.90's is steeper in first and second.
However, most guys don't go with more than 3.73's with the A4, that gives: 11.41, 6.08, 3.73
So even the 3.73's gives you a deeper first and second gear.
I would like to do 3.42's with the A6 and run it through the quarter mile like a 4 speed. Fourth would be 3.42 x 1.15 = 3.93. Only trouble is first gear would be a real stump puller at 13.75 which would require some seriously sticky tires.
Any updates.
