Header question?
Old Sep 27, 2006 | 12:36 AM
ydlee24's Avatar
ydlee24
Default Header question?
Adding long or short headers will it cause the engine light to come on? And what are the down sides of adding them? Warranty?
Old Sep 27, 2006 | 12:50 AM
achilds's Avatar
achilds
I installed American Racing headers myself. No check engine light (CEL) and I have been running them for months now. The only down side is emmisions if it applies in your state. Many dealers will still honor you warranty with them installed, besides you can always switch back if you have a major problem.
Old Sep 27, 2006 | 12:57 AM
midnite902's Avatar
midnite902
Most of the check engine lights resulting from headers are from the rear O2 sensors. A good tune will keep them from happening. If you installed yourself and you are careful with the O2 sensors you will probably not have a problem.
If you install headers, you should get a tune. Headers allow for a much more effecient AF ratio and timing settings
Old Sep 27, 2006 | 01:16 AM
glennhl's Avatar
glennhl
I've done headers on an 01 Z28 and an 06 C6. Got the CEL's on the 01 Z28 and a tune didn't make the CEL's go away until they actually turned off those codes in the computer.
Luckily I have not had any CEL's with the LG Pro LT's on my C6.
Old Sep 27, 2006 | 05:36 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I had the PO430 rear o2 code & light with my headers. I'd reset it and it would come back a day later until I got the tune and the code was turned off.
Old Sep 27, 2006 | 02:04 PM
EuroRod's Avatar
EuroRod
My DynaTech headers have been on the car for about 3 weeks now. No CE lights. I had the headers Jet-Hot coated. Thats helps keep the heat inside the tubes, and lights off the Hi-flow cats quicker. Very satisfied with their system. Easiest install I've ever had. All the parts were in the box. Bought them from Tybrne. BIG
Old Oct 1, 2006 | 08:09 AM
Kreuzen's Avatar
Kreuzen
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Kooks long tubes -- no problems after 2-years.
Old Oct 1, 2006 | 01:32 PM
VET4LES's Avatar
VET4LES
One down side could be emission test. In California they must be CARB (California Air Resorces Board) approved. Some test stations check and others don't. I put Doug Thorley headers on my motorhome and I was ask for the approval several times but most of the time I was not asked.
Old Oct 1, 2006 | 01:36 PM
gdawgg's Avatar
gdawgg
I had Dynatech headers for about 3 months before getting a tune and have had no problems with check engine lights before or after the tune.
Old Oct 1, 2006 | 11:02 PM
jjohn918's Avatar
jjohn918
I've got LG Pro long tubes minus the cat (off road) and I have the check engine light. I plan on having them turn it off when I have it tuned.
To Header question?
