PCV - Basic Question
Old Sep 29, 2006 | 01:21 AM
kelp's Avatar
kelp
Default PCV - Basic Question
Question is basic. Why ventilate? What's so great about burning nasty waste gasses up to keep the crankcase air clean, and gum up the upper end of the motor? Sheesh.
Also, to draw air through the (oil reservoir in my case) and eventually going into the intake manifold, you basically are creating a vacuum leak. Why not keep the vacuum high (and have better throttle response)?
All I see are disadvantages to PCV ventillation, when I put some thought into how the overall system operates and not take it for granted.
So I did reroute my PCV lines, and get faster throttle response (just great!), and it seems to run much better. So, then I really started thinking
Old Sep 29, 2006 | 06:55 AM
VET4LES's Avatar
VET4LES
It's for smog and the EPA. The car is tuned with that vacuum leak, when you plug it the engine will run richer and may require a tune. In addition you will not pass the emission's test.
Old Sep 29, 2006 | 06:56 AM
timd38's Avatar
timd38
We have these people that work for the EPA and they control the amout of emission that a vehicle can put out and the PCV valve is part of the emission controls.
Old Sep 29, 2006 | 08:21 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
good question.
pcv or 'crankcase' ventilation relieves the buildup of pressure inside the crankcase/engine.
if the system is not ventilated you will build enough pressure inside the engine that 'seals' will begin to blow, the engine will need to work against the pressure, oil won't move as freely, etc., etc.
you don't have to route it into the intake if you don't want too, that's where the epa comes into the picture. instead of venting the 'gasses' into the atmosphier they (epa) mandate that the 'gasses' are returned to the 'system' and burned.
it is common practice to use a 'crankcase filter' on the vent instead of routing it back into the intake.
when it routes into the intake you are no longer getting 'clean air', you are getting a combination of air types. some hot, some not, some dirty, some clean.
Old Sep 29, 2006 | 10:36 AM
Vet's Avatar
Vet
I'd think that, especially for a street engine, the PCV system is a very good thing. It positively removes blow-by gasses, etc (fuel, vapor, etc) from the crankcase so that such contaminants do not condense into the oil. With just a mere breather and no PCV system, I'd think the inside of the crankcase and the motor oil would get dirty / contaminated much faster. The PCV is purging the crankcase all the time, pulling bad stuff out and sucking "clean" air in. The downside is that you can see oil contamination in the intake, heads, etc. Some people use an oil catch can to reduce this problem... basically a filter in the PCV path that separates the oil from the gasses so that not much oil vapor makes its way to the intake. Most motorcycles have such oil separators from the factory... and they work. I believe Elite Engineering makes an oil catch can for Corvettes. Personally, I'd much rather install a catch can and leave the PCV in place as opposed to undoing the PCV and adding a mere open breather... because I'd like to keep my crankcase clean.
Old Sep 29, 2006 | 10:38 AM
Vet's Avatar
Vet
EDIT: Sorry... accidental duplicate post... the forum has been running slow and quirkly lately... often the page times-out before the post goes in, I often lose my text before the post is submitted... very frustrating... I now "copy" my posts before hitting submit so I don't lose my text. Anyway, sorry for the extra accidental entry here... the post had timed-out and page went blank... I assumed the post was lost so I tried again... but alas the original HAD gone through also... ooops.
Old Sep 29, 2006 | 10:46 AM
haljensen's Avatar
haljensen
Any internal combustion 4 cycle motor builds pressure in the crankcase, the pressure has to be relieved for the engine to operate correctly. Some extreme horsepower applications even use a pump to create a vacuum in the crankcase. The choice of where to relieve the pressure is yours. There are any number of ways to separate the oil from the blowby gases, aftermarket kits and DIY. Before pollution regulation we just vented the crankcase to the outside air. Now we vent the pressure to the intake to recover the blowby gases. You can just vent the crankcase but you won't pass a strict emissions test.
Old Sep 29, 2006 | 10:51 AM
Zig's Avatar
Zig
Originally Posted by Vet
I'd think that, especially for a street engine, the PCV system is a very good thing. .... With just a mere breather and no PCV system, ...the crankcase and the motor oil
will
... get dirty / contaminated much faster .... The PCV is purging the crankcase all the time, pulling bad stuff out and sucking "clean" air in.
hhhmm.. install an inline filter... (kinda like a motorcycle fuel line filter)... just keep an eye on it, don't want it to fill up ??
best of both worlds ??
what if both sides were pcv filter vented ?
Old Sep 29, 2006 | 11:40 AM
HITMAN99's Avatar
HITMAN99
Originally Posted by Zig
will
That is basically what a catch can is --- an in-line filter with an oil reservoir. The filter part is usually just wire mesh though. Some guys have used an air/oil separator from an air compressor, works pretty well.
There is no need for a pcv valve on the supply side. The whole purpose of the PCV valve is to let gasses go through, but no oil. Since there is no oil or crankcase fumes on the supply side, no need for a PCV valve.
Old Sep 29, 2006 | 12:12 PM
Vet's Avatar
Vet
...just keep an eye on it, don't want it to fill up ??
On a few motorcycles I had, there was an "oil separator" tank inline between the crankcase and intake. It had a drain tube at the bottom, and every so many miles you were supposed to pull the plug from the drain tube and drain out whatever was in there. I did so, and indeed, every few thousand miles some crud would come out... seemed to be a combination of oil and water, a mayonnaisey kinda solution. Considering the amount of stuff that built up in there and the size of the tank (not too big), I probably could have gone 20k miles or more without draining the tank with no problem. But that was on a given "small" 1100cc (1.1 liter) engine. Other set-ups will vary. I once worked on a 455 engine (7.5 liter) with no windage tray and a PCV valve that was in a direct line of fire to the crankshaft with no baffle... that thing was sucking oil into the intake by the quart, that was a big problem that needed to be dealt with. Not sure how the LS2 relates to all this. I'd like to think that a stock LS2 that does not see constant track use can get away without any PCV modification. Comments?
Old Sep 29, 2006 | 12:40 PM
HITMAN99's Avatar
HITMAN99
The LS2's are much better in this regard than the LS1's were, especially the earlier models before the LS6 intake manifold came it. The LS6 had the vent line coming from the valley cover instead of the valve cover, and worked much better.
Before the catch cans became popular, guys used to to the "vertical PCV" mod, where they used a PCV valve from an earlier year V-8, and mounted it vertically, which made it harder for oil to get sucked into the intake.
There is a fairly easy way to determine how much oil is getting past your PCV valve, and into the engine. Just remove your MAF and airbridge, reach into the throttle body and open the butterfly, feel the back of the blade. If your hand comes out all black with oil, you're getting contamination.
Old Sep 29, 2006 | 01:17 PM
Zig's Avatar
Zig
hhmmm.. pretty handy.
i'm currently enviromentaly bad. i was going to have the crankcase vent on my bike into a flask, mounted up against the oil tank. but currently, it just vents to the outside.
popping a drain valve into the bottom isn't a bad idea.
i've seen the same thing out of a 350. when not properly vented.
pcv valve that was in a direct line of fire to the crankshaft... ?? huh ? where was it located ? in the block ??
i bet.
it probably could, who knows ?
how much of a difference would it make ? under what type of conditions ? etc.
Old Sep 29, 2006 | 01:35 PM
Zig's Avatar
Zig
they simply replaced the valve with the 'old' style ?
all of the old v8 pcv valves i've worked with have been vertically plugged into the valve cover.
i wonder what it would take to retrofit an older ls6, valley vent, onto the ls2 ?
Old Sep 29, 2006 | 01:55 PM
HITMAN99's Avatar
HITMAN99
It wasn't quite that simple, as the LS1 PCV mounting assembly also served as a ground strap (don't ask why, I don't know). There were dozens of earlier PCV valves that would work.
Why in the world would you want to retrofit the earlier LS6 intake and valley cover to an LS2?
There were lots of guys who wanted to swap the early LS1 intake for the LS6, for flow reasons. You had to grind off a casting boss inside the engine to do it, otherwise it was a direct bolt-on. The valley cover feed to the PCV was just a convenient add-on benefit.
Old Sep 29, 2006 | 02:08 PM
Vet's Avatar
Vet
The PCV was in the valley pan of a Pontiac V8... and the lifter valley area on that block is open in the middle, you can see right down into the crankcase past the cam. It wasn't a true "direct" line of fire, but probably as close as you could come to it. The valley pan did have a bit of a baffle on it, but still, the overall design allowed for lots of oil vapor to be drawn through the PCV valve, which was mounted vertically. You could pull the hose off the PCV valve and oil would be pouring out. Pontiac attempted to deal with this issue on the 455 S.D.... they relocated the PCV valve to the valve cover etc.
This has always been a problem with big old V8s... I've seen Buicks and other V8s that had their intake runners coated with oily sludge due to oil being sucked in though the PCV valve... intake valves fully coated with thick oil sludge, etc... ultimately resulting in detonation etc. I'll never understand why the manufacturers never seemed to try to do much about this problem, at least back then. All of those engines should have had some type of catch cans and/or improved PCV designs to keep oil out of the intakes.
Old Sep 29, 2006 | 02:18 PM
Zig's Avatar
Zig
i got the impression when you said that the ls6 'valley vent' worked better than the ls2 which in turn was better than the ls1, you were referring to the pcv system.
i wasn't referring to the 'intake', just the 'vent'.
Old Sep 29, 2006 | 06:38 PM
VET4LES's Avatar
VET4LES
I thought it was just me.
To PCV - Basic Question
Old Sep 29, 2006 | 07:16 PM
cbrf4i1's Avatar
cbrf4i1
which one is the supply / clean air line? i put a filter each in both lines and both filters have small amount of oil.
Old Sep 29, 2006 | 09:36 PM
kelp's Avatar
kelp
Oil catch can installed this evening.
Old Sep 29, 2006 | 09:58 PM
cbrf4i1's Avatar
cbrf4i1
nice, where did you get that tiny "catch can"? thanks
