PCV - Basic Question
Old Sep 30, 2006 | 12:07 AM
kelp's Avatar
kelp
http://www.anver.com/document/vacuum...lters/fltp.htm
I still have some more experiments to do.
Old Sep 30, 2006 | 10:04 AM
HITMAN99's Avatar
HITMAN99
Originally Posted by cbrf4i1
which one is the supply / clean air line? i put a filter each in both lines and both filters have small amount of oil.
Really! VERY interesting! I never woulda thunk it.
That is a very neat little setup you've got there. Having previously paid big $$$ for a fancy anodized aluminum catch can, your setup looks much more practical.
Old Sep 30, 2006 | 11:48 AM
haljensen's Avatar
haljensen
Oil catch cans are used on most forced induction motors since they have higher cylinder pressures and more blow by. Can't hurt on a high compression LS2. I had a catch can on my SRT4 and had to empty the filter every week (20 pounds boost causes a lot of blowby).
Lots of options; $80 to $150 aftermarket and DIY for around $20 using an air compressor filter like a Campbell Hausfeld. Try a search on "oil catch cans".
Link;http://www.pbase.com/rsrock/oil_catch_can
Old Sep 30, 2006 | 05:27 PM
HITMAN99's Avatar
HITMAN99
I thought it looked like an air/oil separation filter from an air compressor. On my C5, I used to empty around 1/3 cup of oil from the catch can every oil change.
Old Sep 30, 2006 | 09:29 PM
C6dude's Avatar
C6dude
I made one for my FI C6. It has a Bosch vaccum pump, attached to a modded(shortened) catch can and a air dryer in case any vapors get by.
First I plugged up the throttle body inlet.Then I took that hose (from the intake valley) and I connected it to the Right side valve cover tube.I made a connector that screws in the Oil fill hole to suck out fumes. The oulet of the pump is attached to my air cleaner so it has constant vaccum pulling all the filtered crankcase fumes. At about 1 psi of boost, the motor kicks on to help suck out the rest and create a vaccum in the crankcase.Vaccum in the crankcase makes for a more efficient running engine
If you want to use a similar setup in a NA car,you just get a MSD or any RPM switch instead of a boost switch. Then adjust it to kick on at any RPM's you desire or let it run all the time if you want.
It Works great. No oily Throttle body or any smoke when I get on it,it has very clean exhaust. heres a couple of pics.I also have them posted on another thread.
Old Oct 13, 2006 | 01:10 AM
Dirty Howie's Avatar
Dirty Howie
