Vortex Cold air / Engine Light?
I recently had a Vortex cold air intake installed. It works great until I take my car on the highway and push it 90 -100 Mph. Then the engine light come on 10 -15 min later? I brought the car into the dealership to clear the codes but happened again last night. Do you think I need a Tuner to correct the problem?
C6 corvette/ 6 speed/ 4,000 miles.
Help!
Help!
I would offer two things: first, the cause is more than likely minor in nature, especially if the car seems to be running just fine; and second, yes, you probably will have to get a competent tune to completely eliminate this problem if it persists. Before spending $300-500 on a tune, however, I would suggest you first purchase your own code reader (Equus Innova 3030, $70 or less from Walmart or on the web, or any number of other OBDII readers, which are also CAN-enabled for the C6), so you can read the codes yourself and reset. If you read the codes and they appear minor (i.e., small leak detected in air intake system, gas cap loose, etc.), try to tweak whatever it is if that's doable without special tools and/or equipment. If the problem persists (and there is a good possibility that it will), then you might consider a tune. But my experience is that a code reader is an invaluable tool with today's vehicles, especially with the way manufacturers have programmed them to light the CEL at the drop of a hat. HTH. Good luck!
I have the Innova 3110 and it works great. There are a lot of good ones available and they all do different things. It is important to check them all out and get the one that sounds best to you as long as it's CAN- enabled as mentioned above.The Best of Corvette for Corvette Enthusiasts
cai dosn't cause cel. the cel is usually caused by faulty / in perfect reconnection in the intake plumbing.
What do you guys think?
http://forums.corvetteforum.com/show....php?t=1504068
the code is caused by the screen being removed..
the air is actually bypassing the sensor portion...
its very common.
reinstall...
if you are in ca I have a couple mass air flow sensors....
if not s.o.l.
any other help
udriveslow@yahoo.com
There are several posters here who have said they have problems with their aftermarket CAIs causing CELs. My comment about CAI installation was meant to imply that even the install process can introduce leaks, etc. that you need to be aware could cause a CEL. I think anytime you fool with the intake or the exhaust from the manifold past the cats, you run the risk of CELs: that's just the way these cars have been programmed by the manufacturer. At any rate, I think the consensus seems to be removal of the MAF screen is the culprit in this case...still, a CAI install problem, I would argue.
I think a tuner should take of this problem.
Well, you can either put the stock intake back and hopefully it will clear the lean code, or get a dyno tune. Otherwise your car will run into the cat-protect mode which will make your car run crapy.
