Fuel pressure meter
Old Sep 30, 2006 | 06:44 PM
kelp's Avatar
kelp
Default Fuel pressure meter
I am trying to hook up a fuel pressure meter to the fuel rail, preferably with a scrader "T" so I can still access it. However, I have not found any permenantly mountable gauge / adapter combinations to make this happen. Is there one on the market?
Old Sep 30, 2006 | 06:57 PM
VET4LES's Avatar
VET4LES
Check Jegs and Summit. I had one on my C3 but you need one with higher pressure readings.
Old Sep 30, 2006 | 09:38 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
How about this?
http://www.bmracing.com/noflash/prod...uelGauges.html
Old Sep 30, 2006 | 11:28 PM
kelp's Avatar
kelp
Nice gauges, wrong adapters. At the end of the fuel rail is a male schrader valve.
Old Oct 1, 2006 | 10:46 AM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Default Be Safe
Use an electric transducer on the fuel rail. It is not a good idea to run any tubing with gasoline under pressure into your passenger compartment. Tubing, fittings, even gauges, have a funny way of leaking at the MOST inopportune moment in time . . . . .
Old Oct 1, 2006 | 12:34 PM
VET4LES's Avatar
VET4LES
The one I mentioned above was under the hood at the carburator. I thought we were talking about an under hood gauge.
Old Oct 1, 2006 | 12:53 PM
The Clevite Kid
Upon re-reading the original post I agree, he was asking about an under-the-hood gauge, on a tee, so he could keep the Schraeder valve. But he probably was NOT interested in pressure at his "carburetor."
Old Oct 1, 2006 | 01:12 PM
I1uluz's Avatar
I1uluz
It's a AN-4 male fitting on the fuel rail, use a Russel Performance FUEL PRESSURE TAKE OFF #670290 and a FLARE CAP # 66195 to seal the other end. That way you can clock the sending unit to clear the covers.
You'll need to remove the valve from the rail before you put the parts on.
The higher end Auto Meter gauges have a very small sending unit that would work well in this setup. The cheaper gauges have rather large sending units. They run around $200 for a good gauge.
For hooking up a "T" a Areoquip Female Flare Swivel # FCM2914 and a Union Tee # FCM2061 will get you the parts you are asking about to hook a gauge up under the hood. That will give you two AN-4 ports open off the fuel rail.
Old Oct 1, 2006 | 02:07 PM
SickRick's Avatar
SickRick
BEWARE the autometer sender. I'm on my 3rd one (and from the looks of it, the 3rd design change). Symptoms of failure are steadily dropping FP's, until the gauge reads so low that the car can't possibly be running (even though it is). They started out with a large sender, in a metal can/case, moved to a smaller one with a plastic rear, then to an even smaller one...
Rick
To Fuel pressure meter
