Serious Cam Advice
I need some real advice.
I want to pass smog in California. Dont want to go too aggressive and hurt the motor.
What I have decided to do is:
Port the oil pump.
Upgrade the timing chain
Springs, seal, pushrods
SO, what cam do you reccomend? This is a 2006 mn6, Z51, with long tubes, cai, etc. Currently at 385 rwhp, would liek to get into the low 400's and have a reliable motor that I dont have to worry about destroying or having reliability problems.
I am looking for more HP at the higher end as the low end seems fine.
Your input is greatly appreciated.
I don't remember if we had this conversation, but in case you did not know, I've been down this road. I looked at all the ways of getting NA power in my C5... built LS1, LS1 stroker (382), LS2 stroker (402), C5-r (427), etc. I eventually wound up with an LS2-based 402 stroker. Like you, I had the same concerns. I'm certain that with your stock block LS2 you can pass smog (sniffer anyway) with a 224/228 cam. Stay under .600 lift, and either a 114 or 113 LSA.
HTH!
1) 224/228
2) 224/230
3) 228/232
Yes, I also want to keep the intake and duration under .600, and have been told to stay with a 114 LSA.
Regarding my "tuner" in Irvine. Yes, he is the best, ultimatley I will trust his decision, as I am an EXTREMELY **** person, I do not like to leave anything to doubt.
I solo'd my first plane when I was 14. At 15, my instructor 'fired" me and said I need a new instructor. (maybe I had bad breath)
After 5 flight instructors, I realised that each one gave me something different in wisdom and skills. It doesnt mean one was better, just that they all reinforced each other and each made me think of issues I never would have thought about.
Variety is the spice of life.
For H&C no headers, the consensus for CA seems to be a 222/222 .580 144 LSA or wider to ensure a pass. AFR205 heads, of course. That gets you 400+ with a tune.
Since you already have LT headers, I'm assuming you have found a way to pass visual inspection.
To maintain street manners, emissions, and gas mileage, you want to keep your valve overlap to a minimum. Of the cams you mentioned, the 224/228 on a 114 will do best, will give you solid gains throughout the RPM band. The 222/222 that was mentioned will also do well, but I wouldn't recommend it with the stock exhaust.
Unless you plan to spend a lot of time at the track, and spin the motor over 6500 RPMs, you do not need to port the oil pump. With a relatively new car, you probably do not need a new timing chain, although the aftermarket units are definitely better than the OEM piece. So if it would give you peace of mind, go for it.
The problem with the SLP rockers is that they are expensive, and cost way more than a cam. You will need new valvesprings and hardened pushrods either way. The install cost for the cam is a bit more, but not that much. In general, SLP rockers are great for stealth, and if you want to claim that you have "stock internals". But the cost per HP is high.
If you want to also get heads, now you're talking another $2K or more, depending on which vendor you go with.
Good luck with your choice. You will get lots of opinions, but unless you're planning to do the install yourself, I'd go with whatever your installer recommends.
Port the oil pump.
The timing chain is fine, it's the same one used in the Z06, it's plenty strong.
That cam will drive pretty close to stock and your motor will last as long as it would stock. You will get over 400 HP easily.
Steve.
Basically what cam would you recommend installing alone, without any change to the valve train at all? And, would it be engine safe?
Sorry to sound like a moron, just trying to understand all this.
You will need springs no matter what cam you choose, push rods should be used but some will argue that point.
As a general rule, when you replace a cam you also replace:
Springs
Push Rods
Timing cover/oil pump gaskets
front seal
crank bolt
oil/filter
Some vendors will sell all of this as a kit.
1) 224/228
2) 224/230
3) 228/232
Any cam shaft worth installing, and all high(er) ratio rockers, will increase lift. Generally speaking, the higher the lift, the stronger the valve springs need to be, in order to slam the valve closed. The stock springs are capable at stock lift, but not much more. As a general rule of thumb, greater than stock lift (but under .600) requires a Comp 918 or equivalent; over .600 requires Comp 921 or equivalent. Hardened pushrods would not be out of the question either.
1) 224/228
2) 224/230
3) 228/232
First question is, do you have LT headers on the car already?
Second question is, is this an M6, A4, or A6?
The 224/228 cam is a proven winner, will idle well on an LS2, give you great power. Best used with LT headers, will work with the M6 or auto tranny. With an auto, you may need to raise the idle 50-100 RPMs.
The 224/230 is a variation on the same theme. The extra exhaust duration will help out if your are not running LT headers, & will help the top end a tad. Idle could be very slightly more lopey.
The 228/232 is a more recent grind that has been very popular lately. With this much duration, you should be running LT headers, and IMHO this cam will also do best with aftermarket heads. This cam has a decent amount of overlap, so the idle will be rougher, and you will probably need to raise the idle speed even on an M6. Several guys have reported that this cam, with proper tuning, can be quite docile on the street. You should get great power with this cam.
http://forums.corvetteforum.com/show...ight=224%2F228
Added a FAST 90 intake: made 425/405.
Added 215 ET heads made 461/435
BTW there is no upgraded timming chain ( like a double roller ) because it woun't fit due to the cam sensor being in the front of the motor. They only fit LS1 motors. I put a new factory chain on, and I haven't herd of anyone with a chain failure yet. As for smog, well....anytime you start increasing the time the valves stay open ie duration, the ppm reading is going to surpass the acceptable levels. Even with the cam listed above. I really don't know if the car will pass the sniffer. That's years down the road and the car will be gone by that time. Only to have another.
