Why the hesitation
Old Dec 21, 2006 | 10:47 PM
LS1LT1's Avatar
LS1LT1
Originally Posted by JLinNY
Off the line there is no hesitation at all. In 1st gear it snaps your head back.
Old Dec 22, 2006 | 10:10 AM
debmwb's Avatar
debmwb
Originally Posted by Evilways
I've felt the notorious torque management kick in once....felt like the car lost 6 cyls. Happened while TC and AH was on and i kicked it in a straight line,guess I got too much traction or not enough for it, couldn't tell, it lost too much power. Hopefully I can get that crap tuned out. The electronic throttle does take some time getting used to, does anyone know of a way to improve the throttle response on these? I know all the tricks for the manual throttle, but like I said, am new to the electonic ones.
You felt active handling. Torque Management is always there and can not be "felt". You would feel quite a difference if TM was removed (/altered), as the car would respond much differently. Altering the TM settings can only be done with a tune.
Old Dec 22, 2006 | 10:12 AM
debmwb's Avatar
debmwb
Originally Posted by Doug411
Does C6 have electric throttle? Or is it just an additional electronic throttle control? I like traditional mechanical throttle.
Yes...the C5 and C6 have "throttle-by-wire". The "gas pedal" is connected to the PCM via wire, and the PCM controls the throttle body by wire. Better throttle response can be had by porting the throttle body.
