External Temp Reading
Old Oct 10, 2006 | 02:13 PM
arm's Avatar
arm
Default External Temp Reading
Just noticed that my center console exterior temp reading stuck at 56. Doesnt readjust. Any simple fixes???????
Old Oct 10, 2006 | 04:09 PM
dashotgun's Avatar
dashotgun
search on my name had the same problem and we had a long discussion. basicaly drive the car for 10 minutes it is normal for it to lag
Old Oct 10, 2006 | 06:37 PM
VET4LES's Avatar
VET4LES
Make sure the wire is connected to the sensor. It is on the passenger side of the radiator down low. This has happened to a few members.
Old Oct 10, 2006 | 07:50 PM
arm's Avatar
arm
Default temp reading
It fixed itself-
After long ride it must have reset- very strange to say the least!
Old Oct 10, 2006 | 09:00 PM
knkali's Avatar
knkali
it didnt fix itself -either it is working according to the manual specs or its broke. Mine "fixed itself" many times. Finally a new sensor did the trick
Old Oct 10, 2006 | 10:34 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I notice when I wash my car, the temp reading will be skewed for a while. It always resumes normal operation after it 'airs' for a while.
Old Oct 10, 2006 | 11:39 PM
Vette_DD's Avatar
Vette_DD
It fixed itself-
No, after being told 5 hours earlier that it was normal for it to lag, someone still didn't read their manual.
2006 owner's manual, pages 3-28 & 3-29 (pages 181 & 182 of the 2007 owner's manual)
There is also a sensor located behind the front bumper.
This sensor reads the outside air temperature and
helps to maintain the temperature inside the vehicle.
Any cover on the front of the vehicle could give a false
reading in the temperature.
If the outside temperature goes up, the displayed
temperature will not change until:
• The vehicle’s speed is above 10 mph (16 km/h) for
five minutes.
• The vehicle’s speed is above 32 mph (52 km/h) for
two and a half minutes.
These delays prevent false readings. If the temperature
goes down, the outside temperature will be shown
when you start the vehicle. If it has been turned off for
less than three hours, the temperature will be recalled
from the previous vehicle operation.
To External Temp Reading
