Z51 vs. Base performance?
Old Oct 14, 2006 | 07:34 PM
glennhl's Avatar
glennhl
Originally Posted by Cjunkie
we just must have some old grey hairs that cant drive i personally WITNESSED 3 06 A6 vettes at the dragstrip and none could get better that a 13.2x hell one pass was a 14.1x ....Ive WITNESSED A4/3.15 cars go 12.8x-13.2x, just what ive seen here in OHIO.
Went 12.831 at 112.4 last night in my A6 and that was at a 3700 foot DA! Grey hairs shouldn't matter, I've got a whole head full of them.
I can't understand how someone could go that slowly in an A6, I mean you don't have to shift or anything. I only ran twice, my other run was also a 12.834 at 112.34. It's pretty hard to drive an auto slowly.
Old Oct 14, 2006 | 07:49 PM
Cjunkie's Avatar
Cjunkie
thats a great run and im happy for you (seriously) lol it just must be here im sure if you seen what ive seen youd be telling these guys to take the cars back to the dealership....i dunno maybe they are running these cars at 230 degress with the TC on????
Old Oct 14, 2006 | 08:10 PM
glennhl's Avatar
glennhl
Good point, the computer really pulls timing with hot temps. The 160 stat really helped my car become consistent. However, with a manual you can shift at too low of rpm, or you can shift slowly, or you can leave the line and spin the tires, etc., etc. But with an auto it's really hard to screw it up.
Old Oct 14, 2006 | 09:43 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Nope, I have on very ugly 17.15 run....... smoked them really bad out of the hole, got a little sideways and nearly hit the wall at Englishtown last year. All it takes is someone to break in front of you on a really cold night with the TC/AH off. (05 A4/3.15s)
Old Oct 14, 2006 | 09:57 PM
glennhl's Avatar
glennhl
That's my worst nightmare. Glad you saved it. Last night a guy in a GTO lost control about 150 feet out and hit the wall. Wasn't hurt, but the car was.
Old Oct 14, 2006 | 10:07 PM
robvuk's Avatar
robvuk
There's no excuse for that to happen on a dragstrip with a car that has Competitive Driving mode.
Old Oct 14, 2006 | 10:20 PM
saplumr's Avatar
saplumr
Inexperienced drivers are more than capable of allowing this to happen. Depending on mods, traction control can be of little to no assistance.
Old Oct 14, 2006 | 10:27 PM
robvuk's Avatar
robvuk
I'm not talking about traction control. I'm talking about AH. Traction control MUST be off for any decent 1/4 mile run. AH is totally non-intrusive under those conditions and only saves your butt when you need it. It has nothing to do with inexperience. A car can get away from you fast. AH can save you.
The only inexperience is someone who hasn't read the manual to understand what AH does and how to engage it with traction control off. No dragracing should be done without it.
Old Oct 15, 2006 | 10:58 AM
Wass's Avatar
Wass
St. Jude Donor '09-'11
Originally Posted by yell03
By the way,
For 2007 Chevy republished their data.
Z51 manual is 4.1 and 12.5@115
non-Z51 manual is 4.2 and 12.6@115
A6 is 4.5 and 12.9@110
Also, all manual coupes are lested as top speed 186.
Actually it has been republished since 2006 (pictured below). Some may prefer the 2005 publication because it shows a larger spread between base & Z51 in 0-60 time and braking distance. 2005 data also only lists Z51 capable of 186 mph with other coupes to be determined. Updated data closes the gap.
Old Oct 15, 2006 | 11:20 AM
yell03's Avatar
yell03
Yep, that's the info I was talking about
Old Oct 15, 2006 | 11:49 AM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
I noticed a couple of things about that one because I have it too.
Actually updated data "closes the gap" in a few "questionable" categories.
I notice that it lists 60-0 braking as 113ft for all models. This would include the Z06. The have the specs listed for the Z06 in all the preceding categories. Come to this one and it brakes just the same as all the rest? I don't think so.
I am wondering how the 0-60 braking dropped all the way from 125 feet in '05 down, to 113 ft in the base cars, and from 116 ft down to 113 ft in the Z51. Again, I don't think so.
The 0-60mph base manual went from 4.3 seconds in '05 down to 4.2 seconds in '06. I am also wondering what they did to the '06 manualss that allowed them to pick up a tenth in the 0-60 mph time.
The automatics picked up a tenth from '05 to '06, but of course, they did have a transmission and gearing change over that time.
I also notice that they have all coupes listed at 186mph for top speed.
But in http://www.corvettemuseum.com/specs/...wertrain.shtml
..."Also, a lower fifth gear gives the Z51 better fuel efficiency and a higher top speed than base models. To increase durability in sustained high-speed situations, the Z51 and the base European manual-transmission models have a transmission cooler."
So there are a few inconsistencies with that page 28 of Corvette Quarterly.
Old Oct 15, 2006 | 11:52 AM
LS1LT1's Avatar
LS1LT1
Are you sure it doesn't effect launch at all? As in preventing the car from squatting/tranferring load (helpful in obtaining a better sixty foot in these cars in most cases) or anything?
I turn it off for that reason but if it really isn't intrusive at all I won't.
Old Oct 15, 2006 | 01:57 PM
  #33
Wass's Avatar
Wass
I guess you will have to ask GM to answer some of your questions! However, my guess on the updated 186 mph top speed is that in 2005 they had not tested base cars yet (listed as TBD). By the time 2006 models came out, they had tested base cars for top speed, and updated the publication. The Corvette Museum link you report is for 2005 models. There is a Corvette Museum link for 2006 where they report 186 mph for all coupes. See the paragraph under Aerodynamics. "The C6 stands out as the fastest Corvette ever produced. The Corvette coupe can achieve 300 kph (186 mph) - a threshold that distinguishes supercars from the rest of the pack. The Z06 has even higher potential."
http://www.corvettemuseum.com/specs/...chnology.shtml
Also Chevrolet.com states all coupes can reach 186 mph. Click this link and there should be an Atomic Orange coupe on the page. On the lower right of the picture click "about this photo". http://www.chevrolet.com/corvette/photogallery/
Old Oct 15, 2006 | 04:08 PM
  #34
'06 Quicksilver Z06
Thanks. I bookmarked that page.
So they're calling the C6 a "supercar" now?
Old Oct 15, 2006 | 05:09 PM
  #35
Wass's Avatar
Wass
Yes...But we always knew that!!
Old Oct 15, 2006 | 06:25 PM
  #36
Tommy D's Avatar
Tommy D
Maybe you shoud try Competive driving mode with rear gear lube all over your tires when its really cold & romp on the gas and tell me what happens
Ah I see that you have not been to a drag strip lately. I usually go on the test & tune night. With all the front wheel drive cars around, it is very hard to race on a night where no one breaks and puts oil all over the track. Cars are constantly breaking drive line parts.
In addition, the track prep at Englishtown leaves something to be desired and if you put oil on it when its cold..... competive driving mode, experience and etc does not help. I was lucky the guy broke at the line. If he had broken at the top end I could have ended up like one of the Mustangs that bounced along the wall on the top end last season.
Next time out I intend to try running with active handling on. I think that active handling & traction control are great but they have their limits.... they do not negate the laws of physics particularly when you have fluids on the track and your tires.
Old Oct 15, 2006 | 06:32 PM
  #37
yell03's Avatar
yell03
Last weekend at E-town a motorcycle dumped oil and tranny fluid all over the left lane right before my run.
After an hour of cleaning the track they gave us the OK to run.
I was in the right lane which they did not even clean up, they said it looked fine.
You bet I was glad to have AH on just in case they were wrong.
The video of that run is up in this Forum now.
Howard
To Z51 vs. Base performance?
Old Oct 16, 2006 | 08:58 PM
  #38
robvuk's Avatar
robvuk
Active handling will HELP keep the car straight under the worst conditions. I'm not saying it's impossible to get the car sideways with AH on. I'm saying that if you do, AH will get you straight again quicker than any human could dream of.
I've never been misfortunate enough to do a launch on an oily track or blow up a rearend, but if I ever do, I'll be sure to have the help of AH on my side.
Old Oct 16, 2006 | 09:01 PM
  #39
robvuk's Avatar
robvuk
Active handling does not do anything to the suspension. AH independently controls each brake to straighten the car in the desired direction by inputs from steering and yaw sensors. As long as the car is going straight, it does nothing. Don't risk playing without it.
Old Oct 16, 2006 | 11:01 PM
  #40
30YR W8T's Avatar
30YR W8T
There are some hard core track folks on this forum and all of the post I have read from them in regards to tracking the car say the same thing. Leave the AH on. It is in your best interest to pay close attention to real world experience.
