Which Gears
so which is it and what are the pro/cons to each if any
Depends if you have Z51 (tranny gearing) or not and also if you plan on using sticky tires/drag radials at all as well.
I would likely start with the other stuff (headers, cold air intake, thermostat, tuning) first though.
also car is nonz51
also car is nonz51
a gear change will turn your car into a totally different animal.....
I've done it to just about every car(truck) I've owned... it makes the SOTP feel like you just put in a new motor
i am planning to get 4.10 on my Z51.... even though most have put 3.90 on Z51 and 4.10 on base cars......
I'm looking for 0-60 fun!!!
shifting though the gears every couple of seconds just having a blast with the car..... we don't have a 1/4 track in the islands and won't have one for a while (few years at least) closed it in the beginning of the year
it will be like my old chevelle with 4.11's only better (have two over drive gears on vette - none on chevelle)
but....... if you plan on 1/4 mile racing with slicks... etc..... it will take a bunch of mods to get it down really fast (low 11's).... 3.90 may be better depending on mods and a whole lot of other things.......
headers are a good mod too...... again depends what your looking for.....
in my other resent cars I've change gears to 3.73 from 3.42/3.09
3.73 works well on the street on my other GM trucks/cars
the overdrive gear on those i believe is about .7 if they were closer to .5 like the vette i would have gone with 3.90 or even 4.11 on them too....
let us know how it turns out for you...... mods...... can't get enough of them!!!!
also when you change the gears do you have to change the whole diff. of just the gears?
Short gears IMPROVE your traction. This may seem counterintuitive, but here is why: wheelspin occurs when torque overcomes the tire's ability to accelerate the car. If the car is accelerating quicker out of the hole, the tire has less inertia to work against (doing less work) and is therefore less likely to break traction. Even if it does, it is more likely to regain it. Also, the driver can modulate better.
You should be OK on stock tires. You can upgrade to the Supercar as on the Z51, it is a much stickier tire. There is also the Michelin PS2, non runflat, but excellent grip. For DRs, you can run a set of 18x9.5 OEM C5 rear wheels with 305 nitto Rs.
I would say gears would especially help the C6, which features a lethargic tune from the factory.
You can either go with DTE, which will ship you a new diff to your specs (basic piece is 1300) and you send them yours back. They hold core charge money until they get you gears. R&R is about 4 hours.
