Ported Intake Question
Old Oct 14, 2006 | 09:56 PM
cmb13's Avatar
cmb13
Default Ported Intake Question
Help me understand....why does the FAST intake require firewall modification? If Chris can port the intake without it taking up more space, basically using the stock intake and modifying it, why can't the FAST guys do that? Is the intake very different? Why would they put out an intake that is such a PITA to deal with?
Just wondering...
Old Oct 14, 2006 | 10:07 PM
saplumr's Avatar
saplumr
The FAST is bigger on the firewall end. The Lingenfelter kit makes it look as though it came that way from the factory. The reason for install is always more HP.
Old Oct 14, 2006 | 10:17 PM
shopdog's Avatar
shopdog
The FAST manifold wasn't designed for the C6. If it had been, it could have been designed to fit without cutting.
Old Oct 14, 2006 | 10:23 PM
saplumr's Avatar
saplumr
That is very true. Because of this it is da@n expensive to install, and more expensive with the ProCharger.
Old Oct 14, 2006 | 11:52 PM
Cory@LS2PortWorks's Avatar
Cory@LS2PortWorks
St. Jude Donor '09
Indeed, the FAST was not meant for the C6. The FAST drops in place of the LS1 or LS6 and accepts those fuel rails. The LS2 was a whole other animal as far as the intakes go. It's really a PAIN to swap a FAST in place of the LS2 intake due to the firewall and the fact that almost everything that goes on the intake must be adapted- fuel rails, injector o- rings, and MAP sensor. Only the TB fits and it isn't in exactly the same location as stock.
For 90% of the guys doing mods it may not be worth it. Not to mention the fact that the dealership service dept. pops the hood and sees whats up instantly. Even a painted FAST with the name ground off looks suspect.
But the FAST does deliver the most gain once ported - hands down.
Old Oct 15, 2006 | 12:07 AM
StarJack's Avatar
StarJack
Did you check the dyno I posted from your work? Not shabby and 1/2 the price (less if you do your own install)!
Old Oct 15, 2006 | 04:59 AM
TTRotary's Avatar
TTRotary
What about not ported, vs. your work...any comparisons out there? Honestly, your stuff flows really well.
Also, what is your process, turn around, and price? PM me if you wish.
Old Oct 15, 2006 | 07:50 AM
cmb13's Avatar
cmb13
Obviously, but are the gains that much better than porting the existing intake? Enough to make the installation worth it?
Old Oct 15, 2006 | 07:51 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
Old Oct 15, 2006 | 09:38 AM
saplumr's Avatar
saplumr
That is the really good question. Mine was done at time of ProCharger install so who knows how much I actually gained from it.
Old Oct 15, 2006 | 01:30 PM
Cory@LS2PortWorks
St. Jude Donor '09
Ported manifolds are able to achieve about 1/2 of what the FAST can. That's why I say that a ported stock manifold is great for about 90% of the guys who mod their cars. The other 10% need ("need" is such subjective word!) the gains that the FAST can give and are willing to pay that much higher premium for it.
Budget is a consideration in all modification plans. Some horsepower is cheaper to obtain. However, when you're trying to scratch out every last bit... it gets expensive hence the FAST pricing and things like electric waterpumps. The cost per hp gained is very prohibitive.
Old Oct 15, 2006 | 05:53 PM
Zig's Avatar
Zig
is that because the FAST runners are larger, use a better flow design, or what ?
Old Oct 15, 2006 | 06:37 PM
Cory@LS2PortWorks
St. Jude Donor '09
The answer is "D" all of the above.
The Plenum is different
The runners are different
and it's a different design geared not toward making a decent flowing intake that meets the manufacturer criteria, but rather a design that does as much as possible in place of the LS6 intake manifold.
Old Oct 15, 2006 | 07:37 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Craig, as you know I'm very happy with my intake that Cory ported. I never thought the Fast was worth it cost wise, it's very expensive and unless you're going for 450+ hp no need to fool with it.
Here's my track results and intake install notes. It's an easy job.
http://forums.corvetteforum.com/show....php?t=1434941
Old Oct 16, 2006 | 11:15 AM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I had my intake ported and gained 15/rwhp and 15/rwtq. $250 for porting and labor for removing and installing intake. Not bad at $17/rwhp.
Old Oct 16, 2006 | 11:26 AM
not08crmanymore's Avatar
not08crmanymore
Default porting
15 HP/TORQUE for 250 bucks ain't bad at all.Who does the porting of the stock thing???I'm interested.I'm in NY.Anybody close??
Old Oct 16, 2006 | 11:39 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Check the link above in my post - Cory (CHarris85Vette) has a good system set up. He ships you one, you swap it out, and you send him your original back. Worked like clockwork for me and the swap is really easy, with the couple of tips I posted.
To Ported Intake Question
Old Oct 16, 2006 | 12:46 PM
Cory@LS2PortWorks
St. Jude Donor '09
so what are your mods and numbers... you never seem to post these? And lets see the dyno while we're at it...
Old Oct 16, 2006 | 01:14 PM
cmb13's Avatar
cmb13
Mods and numbers are in his sig.
not08crmanymore
Thanks Joe.
