Fixing Non Runflats
Old Oct 18, 2006 | 09:33 AM
bt944's Avatar
bt944
Default Fixing Non Runflats
I am worried about switcing to non runflats. Does any have actual real world experience with a can of tire inflator? Did it affect the sensors? I have a compressor and plug kit also, but that may not always be a viable option - so the fix-a-flat would be a backup for me.
Tks
Bill
Old Oct 18, 2006 | 12:24 PM
Wayne88's Avatar
Wayne88
IMO, the car is too low to use a plug kit, without jacking it up.
I do carry a can of Fix a Flat in my other cars, but never had to use it.
Old Oct 18, 2006 | 12:40 PM
06C6Z's Avatar
06C6Z
Having driven Z06's since 01 they did not come with runflats but with the air pump and sealer. Only one time did I have a flat and then I called AAA since the tire was slashed.
I currently have an 06Z and changed out the runflats for non-runflats, I currently carry a AAA card...
To answer you ? I have pluged tires in the past, knowing full well the tires rating has been compromised...
Old Oct 18, 2006 | 06:07 PM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
Doesn't fix-a-flat damage the pressure sensors?
Old Oct 18, 2006 | 07:47 PM
EHS's Avatar
EHS
Yes.
Old Oct 19, 2006 | 11:22 AM
bt944's Avatar
bt944
Originally Posted by EHS
Yes.
Thats would be my opinion too. However many sport car manufactures such as Porche provide a a can of sealant in the repair kit. I believe the ZO6 also comes with sealant and a small compressor. My only thought would be this is a specific type of sealant. Can anyone confirm this?
Old Oct 19, 2006 | 11:42 AM
tluck's Avatar
tluck
I just purchased a kit from Tire Rack which is a pump that pumps a latex based gel into the tire. They said this pump is standard equip. for several exotic cars. The GT40 was mentioned.
Old Oct 19, 2006 | 01:57 PM
EHS's Avatar
EHS
The sealant is a last ditch effort and remember -- the Z06 (C5 version which had non-EMTs) also did not have tire pressure sensors.
So, nothing to ruin.
Old Oct 19, 2006 | 05:58 PM
Dgatto's Avatar
Dgatto
The car isnt to low to use a plug kit, I have allready done it myself....twice.
Plug kit, portable compressor.....your gtg
Doooont use fix a flat.......ever!
Old Oct 19, 2006 | 07:29 PM
GER42's Avatar
GER42
I watched my neighbor fix 2 tires on his friends car. One front and one rear. This 06 has been lowered. No problem.
To Fixing Non Runflats
