hello all im looking into getting a set of drag radials for my C6 and ii dont know of anybody that makes a 19" dr so i was thinking about putting on tsome rear C5 wheels(18's) and mounting DR on them
my question is has anybody done this will the stock c5 wheels mount right up or do i need a certain offset.also what tire/DR size did you go with
go with a c5 Z06 FRONT 17x9.5 and run 17" drag radial since there are plenty available in that size or run a 18x10.5" rear C5 Z06 wheel and run an 18" drag radial. They will bolt right up, if you have a Z51 might want to check the clearance for the caliper but I am pretty sure the 18 will work.
alright and they just fit right on no spacing now is this only with z06 wheels or will the fake ones on ebay work
like say i was on ebay and typed in 2002 corvette and of the 4 pages of wheels that popd up as long as i find a set that are 18x10.5 im good to go
Google up wheel calculator. the 10.5 wheel will stick out to far and look dumb, plus throw dirt on your car and maybe hit wheel well if you hook and the car squats hard
LOL...sorry i just wanna know alot of stuff...when ever i get something new i have to learn all about it
I'm the same way. Mine are ET Streets, 275/40/17; mounted on 17" C5 wagon wheels, from the front of a C5. Fit fine. No need to go to 18s for a drag radial; in fact, a bigger side wall (higher profile) may be beneficial for drag radials.
what is "C5 wagon wheel"?...sorry this is my first vette ..is this the factory rim on the front of the C5?
Will work but a rear wheel from a Z06 is going to stick out a little over an inch further than stock fitment.
A C5 Z06 front on the other hand will only stick out around 19 mm. That should not be too bad.
I widened some C6 fronts to 10.5 inches and I run BFG 295/35/18's. Fit just like stock, just a couple mm off.
Wagon wheels were the first OEM wheels for the C5, I believe they updated to thin spokes in 2000. Same sizes and I believe the offsets are nearly identical also.
They are good light strong wheels but are a tad ugly.
Yes, it's the factory silver 1997-1999 (non magnesium) C5 rims, thick spoke.
Jerry Muniz (black 2005 C6) has a set of those (18x9.5, the C5's rear wheel size) on his car with 295x35 BFG DRs and it fits very well IMO.
