160 T-stat installed
Old Oct 31, 2006 | 05:57 AM
  #81
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
Originally Posted by HITMAN99
... The second parameter is the coolant temp itself ---- if it gets over 186 degrees, that also results in timing being pulled.
i just thought about this...so are you saying that timing begins to get pulled just as the 'stock' therm. begins to open ?
Old Oct 31, 2006 | 06:02 AM
  #82
cbrf4i1's Avatar
cbrf4i1
that quote from hitman regarding timing been pull at 186* ect is incorrect. so the answer to your question is, no. looking at the chart it looks like it starts at 212* and it could pull up to 3 degrees, i have the timing pull from ect chart if you wanted i can email to you.
Old Oct 31, 2006 | 06:06 AM
  #83
Zig's Avatar
Zig
Originally Posted by cbrf4i1
that quote from hitman regarding timing been pull at 186* ect is incorrect. so the answer to your question is, no. looking at the chart it looks like it starts at 212*, i have the timing pull from ect chart if you wanted i can email to you.
that would be excellent
how/where did you get the chart ?
Old Oct 31, 2006 | 06:24 AM
  #84
cbrf4i1's Avatar
cbrf4i1
zig, just email you the chart, feel free to post it on this thread if you want, i don't have a way to posted it. thanks
Old Oct 31, 2006 | 06:47 AM
  #85
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Originally Posted by smokinvette.com
I have a 170 degree thermostat installed... is there a big difference between this and the 160?
What temps do you run at normal cruise? Where did you get the 170 stat? Did you happen to test it for opening temp before you installed it?
Old Oct 31, 2006 | 08:33 AM
  #86
HITMAN99's Avatar
HITMAN99
True dat --- my post was incorrect. I got my numbers mixed up, and my info came from another thread. 212 sounds correct to me.
Old Oct 31, 2006 | 08:46 AM
  #87
Zig's Avatar
Zig
...that IAT is one of the parameters that will result in timing being pulled.
anyone got the 'chart' or settings the iat uses. ie temp and timing ?
if the ecm won't start pulling timing until 212 and we are able to keep the coolant temps under 212 with the 'stock therm.' at what temp does the iat begin to pull timing/advance.
Old Oct 31, 2006 | 09:39 AM
  #88
gtodoug's Avatar
gtodoug
Spark will start being pulled @81.5* under light throttle and 90.5* under WOT operation.
Old Oct 31, 2006 | 11:53 AM
  #89
Zig's Avatar
Zig
any idea what the iat is at operating temp ?
Old Oct 31, 2006 | 02:31 PM
  #90
cbrf4i1's Avatar
cbrf4i1
actually my charts on the iat shows it starts at 86* under light throttle and 95* for wot. zig, iat timing retard chart just got emailed to you, posted if you want.
  #91
cbrf4i1's Avatar
cbrf4i1
i will be doing some scanning this week, i will let you know.
Old Oct 31, 2006 | 02:42 PM
  #92
Brett Hunter's Avatar
Brett Hunter
It depends on what speed you are driving. The IAT can vary from ambient to 60* over. This is the same with all of the airbridges I have seen tested including the bottom breathers.
Old Nov 1, 2006 | 06:44 AM
  #93
gtodoug's Avatar
gtodoug
cbrf4i, my charts show the same thing, however it blends the cells next to each other. So if one cell is 77 and the next one is 86 that gives you a delta of 9* and it will pull timing right inbetween the two. What ever value is in that cell at 86* it will pull half of that number and ramp up to the full amount when it reaches 86*
hope that makes sense.
dougie
Old Nov 1, 2006 | 07:15 AM
  #94
Zig's Avatar
Zig
dougie
after looking at the 'iat timing retard chart', will be poseted once the pic gets approved, we don't have a chance, unless we always and only run during air temps. of 85 degrees or less.
the cell for 86 degrees iat and .32 cylinder air mass shows a value of -1 (minus one) for iat timing retard.
does this mean it pulls one degree of timing or does it reduce the advance rate by a value of -1.
at 86 degrees it uses the -1 value, which to me, means that at 85 degrees no adjustment is made.
i know, finding the 'wind chill' effect is not a valid method to obtain temp. based upon outside air temp and wind speed but according to the chart we don't have a chance, anytime air temp is over 85 degrees the iat will at least be that amount. or am i wrong ?
edit: the chart does show that we can go up to 94 degrees and a cylinder airmass of .72 and above will result in no timing change. at 85 degrees and .32 cylinder airmass of .32 to .39 results in -1, .40 is -2, .44 is -3, .48 to .68 is -4, then .72 up is 0.
Old Nov 1, 2006 | 09:27 AM
  #95
Zig's Avatar
Zig
Default ect chart
here's the ect chart.
Old Nov 1, 2006 | 03:34 PM
  #96
cbrf4i1's Avatar
cbrf4i1
dougie
dougie, i think you and i have a different chart. can you post your chart? thanks
Old Nov 1, 2006 | 03:37 PM
  #97
cbrf4i1's Avatar
cbrf4i1
zig, your total timing advance will be -1, doesn't really matter if it is retarding by -1 or -1 on the advance. and yes, we have no chance if the ambient is above 85*, you can have your car tune to make the timing retard less aggressive, but you certainly don't want to remove it completely to protect your engine. you feel sorry for me now? i am in AZ, 10 months a year the high of the day is above 86*....but i hate snow...
To 160 T-stat installed
Old Nov 1, 2006 | 08:28 PM
  #98
Zig's Avatar
Zig
that has got to rough trying to compare times, etc. with folks in other parts of the country.
snow ain't all that bad. some of the 'strangest' christmas' i've ever spent were in L.A. , it's just something about sunny, 70 and mild that doesn't really say christmas.
Old Nov 1, 2006 | 11:59 PM
  #99
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
You will never get enough cool dense air........... we need to make you an air conditioner to cool the intake charge (just like an intercooler cools the hot supercharged/turbocharged air)
Call me crazy...... I forget which ac line remains cold but if you added a section and ran it through the air intake. You have to run the ac any way because it is hotter than hell in AZ
Old Nov 2, 2006 | 12:24 AM
  #100
cbrf4i1's Avatar
cbrf4i1
tommy, believe me, i even look into water injection and decided against it. not only it is hotter then hell here, i also got 1250 ft of elevation too, i guess it is still better then dever...
