Lowering C6 Help.....
Old Oct 27, 2006 | 08:12 PM
ydlee24's Avatar
ydlee24
Default Lowering C6 Help.....
I got the car on two jack stands and started off with rear. I took off the left rear tire to acess the bolt but can't seem to make it turn. I turned counter clockwise but it will not budge any suggestions?
Old Oct 27, 2006 | 08:22 PM
HITMAN99's Avatar
HITMAN99
I think that after the rear is on jack stands, you have to jack up the spring a bit to relieve the pressure, then you can turn the bolt.
Old Oct 27, 2006 | 09:37 PM
BlackOps's Avatar
BlackOps
From: Evansville, IN The GOCC, rebels without a clue.
St. Jude Donor '06
You'll need to put some pressure on the end of the leaf spring using another jack and then the adjuster will turn easily. I used a small peice of two by four to protect the spring and a small bottle jack. Do a search for "lower" in the FAQ and you'll find several posts on how to go about lowering.
Old Oct 28, 2006 | 07:12 AM
Ginny C6's Avatar
Ginny C6
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
I lowered the rear of ours a while back. If you use the aftermarket lowering bolts with the thin layer of rubber, after a few thousand miles you will start to hear a scraping noise coming from them. It drove me nuts trying to figure out what the racket was, until I realized the rubber pad wore away. I thnk you can buy some neopreme pads to help, but I just re-installed the factory bolts and lowered the car as far as it would go on those. Good luck Kevin
Old Oct 28, 2006 | 08:12 AM
07blkvette's Avatar
07blkvette
how do you lower the front of the car? is it the same as the rear?
Old Oct 28, 2006 | 06:15 PM
Ginny C6's Avatar
Ginny C6
St. Jude Donor '11
Yes, I believe it's pretty much the same.
Old Nov 12, 2006 | 08:33 PM
Mike V.'s Avatar
Mike V.
Default Lowering?
Anyone out there have specifics on lowering car w/ stock bolts, & how much can you get it down.
Thanks in advance. Mike
Old Nov 12, 2006 | 09:30 PM
LEAVINU's Avatar
LEAVINU
Lowered mine a few weeks ago on stock bolts and the front got to where I wanted it- one finger gap from fender, but back didnt make much of a difference. I ended up cutting the whole bushing off the rears to get the same one finger gap and it looks awesome in my opinion.
going to get a buddy of mine to host some pics and then I can post.
Old Nov 13, 2006 | 11:33 AM
1 slow 97's Avatar
1 slow 97
Mike,
this is how much drop you will get with cranking the factory bolts down as far as they will go. The front is fine but the rear needs more so I will be cutting the bushings soon.
To Lowering C6 Help.....
