Premium, regular, or in-between
Old Oct 28, 2006 | 10:46 PM
philiphere's Avatar
philiphere
Default Premium, regular, or in-between
Picked up my 2006 coupe in September. The dealer filled the gas tank, and I never asked what octane they used. I'm guessing regular, but the salesman thought premium (91). In any case, I heard no "pinging" or detonation. I decided on my first fill-up to use premium because I didn't want to risk any detonation during break-in. My style of break-in is to avoid cruise control steady speeds, give it occasional 3-4 second blasts while cruising, and no full-throttle 0-60 type starts. Since auto magazine reports and the owner manual state regular is okay, I'm tempted to try out a few gallons of regular now that I have about 700 miles on the clock to see what happens. Does anyone out there use regular in their C-6?
Old Oct 28, 2006 | 10:50 PM
johnodrake's Avatar
johnodrake
Moderator
Several posts on this subject. Some out there use 87 octane. Most, like me, use 91/93.
Old Oct 28, 2006 | 11:10 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Highest octane you can buy, it just hurts perfomrance if you don't. The ecm will retard spark spark to avoid pinging and cost you in engine power.
Old Oct 28, 2006 | 11:44 PM
zare191's Avatar
zare191
Anybody that de-tunes a Corvette by burning other than premium fuel should save even more money and buy a non-performance car in the first place.
Old Oct 29, 2006 | 12:02 AM
patton's Avatar
patton
St. Jude Donor '09
i agree if ya cant afford the gas stay on the porch. 93 only and i have no idea how much a gal is. i just filler up and give them cash
Old Oct 29, 2006 | 12:05 AM
SickRick's Avatar
SickRick
I burned premium in my SUBURBAN - not reason to burn anything else in my vette (though at my level of mods, I doubt the car would run worth a damn on anything less)...
Rick
Old Oct 29, 2006 | 12:22 AM
cbrf4i1's Avatar
cbrf4i1
Is this a joke, spent $50k on a brand new car and you want to use 87 octan? next question would be which 87 octan is better to use. don't go cheap now.
Old Oct 29, 2006 | 01:16 AM
glennhl's Avatar
glennhl
However, I have heard first hand from a Corvette owner that they actually have filled up with Circle K gas!!!!
Old Oct 29, 2006 | 01:45 AM
AP's Avatar
AP
Circle K 93 is better than 87 ...
Old Oct 29, 2006 | 02:28 AM
BLCK PRL's Avatar
BLCK PRL
We only have 91 octane here in Montana so I add a can of Torco to bring it up over 93 (94.13). Putting regular (87) in a Corvette is like putting a $1000 business suit in the washing machine in order to save on the dry cleaning bill.
Old Oct 29, 2006 | 10:08 AM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
The C6 is factory-tuned for 91, so any higher octane is wasted without a tune. Regardless, we have 93 premium here, so that is what I use. I recall a post from someone who talked with a Corvette engineer at the Birthday Bash this Spring who said running mid-grade, 89, would not produce any pinging or noticeable difference in performance, and actually recommended it.
Old Oct 29, 2006 | 11:21 AM
Hoonose's Avatar
Hoonose
You might as well save a little money and use 87 octane for break in. Later go to 93 octane for best performance. If you stay with 87 octane you'll just lose about 10-15 peak HP.
Old Oct 29, 2006 | 11:23 AM
Hoonose's Avatar
Hoonose
The GM webite says to use 93 octane for best performance, but I haven't found anyone who has data on this.
Old Oct 29, 2006 | 11:57 AM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
The difference in price from 87 to 93 is very insubstantial. Let's say even a $.30 difference a gal, at 18 gallons, you're looking at roughly $5.40 extra per tank. And that's with a full tank refill which never happens. People are willing to spend $1000+ on mods for an extra 10-15hp but don't want to spend an extra $5 to make sure their car is using all it's power potential stock? Go for the 91/93. The extra cost will be noticed more in your head than in your wallet.
BLCK PRL
I have had experience with Torco in other cars and I have found that it quickly fouls out the plugs. It may not be a concern on the LS2 but just giving you a heads up.
Old Oct 29, 2006 | 12:05 PM
Hoonose's Avatar
Hoonose
The same can be said that power difference is more in your head.
Old Oct 29, 2006 | 12:11 PM
k0bun's Avatar
k0bun
I agree 100% but the manual recommends 91+ so...
Old Oct 29, 2006 | 12:29 PM
Vette_DD's Avatar
Vette_DD
Since I'm not a gearhead, I USUALLY go with whatever my owner's manual says. My 2006 owner's manual says this on page 5-5:
Gasoline Octane
If your vehicle has the 6.0L V8 engine (VIN Code U),
use premium unleaded gasoline with a posted octane
rating of 91 or higher. You may also use regular
unleaded gasoline rated at 87 octane or higher, but
your vehicle’s acceleration may be slightly reduced,
and you may notice a slight audible knocking noise,
commonly referred to as spark knock. If the octane is
less than 87, you may notice a heavy knocking
noise when you drive. If this occurs, use a gasoline
rated at 87 octane or higher as soon as possible.
Otherwise, you might damage your engine. If you are
using gasoline rated at 87 octane or higher and you hear
heavy knocking, your engine needs service.
We don't have 91 octane gas, so I'm using 93 octane gas.
Old Oct 29, 2006 | 12:42 PM
timd38's Avatar
timd38
Same here.
To Premium, regular, or in-between
