Drain plug o-ring
Old Oct 29, 2006 | 11:30 AM
Whiterock1's Avatar
Whiterock1
Default Drain plug o-ring
Does anyone change the small o-ring on the base of the drain plug when you change the oil? I didn't at my first, 2000 miles, but wonder if you need to in the future. It sets in the housing of the base and doesn't look like a wear item, but not sure.
Old Oct 29, 2006 | 11:35 AM
glennhl's Avatar
glennhl
I've been changing oil on all my cars for 37 years and have never changed the o-ring. However, I always start my car, check the oil pressure, and then check for any leaks at the drain plug and filter.
Old Oct 29, 2006 | 04:25 PM
BlackOps's Avatar
BlackOps
From: Evansville, IN The GOCC, rebels without a clue.
St. Jude Donor '06
I change mine every time, as a preventative measure.
Don
Old Oct 29, 2006 | 07:11 PM
VET4LES's Avatar
VET4LES
Only it's been over 50 years.
Old Oct 29, 2006 | 07:19 PM
glennhl's Avatar
glennhl
Les, so you started working on your Dad's cars when you were 3 years old???
Old Oct 29, 2006 | 08:36 PM
VET4LES's Avatar
VET4LES
I wish. I'm 67 and had my first car when I was fourteen. Couldn't drive it but I worked on it a lot.
Old Oct 29, 2006 | 09:07 PM
glennhl's Avatar
glennhl
Excellent story, thanks!
Old Oct 29, 2006 | 09:32 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Pointless. Inspect and replace when required...i.e. when obviously damaged, or when you begin to get an occasional drip. You'll probably need a new one in about ten years.
Old Oct 29, 2006 | 09:41 PM
VET4LES's Avatar
VET4LES
I own an XJ8 that I do my own maintenance on and in three years have not replaced it. I spend time on the Jaguar forum and read the same kind of issues. When Jag owners take their car to the dealer for an oil change they replace the drain plug with a built in o-ring at every oil change. The current cost is $12. What a rip off.
Old Oct 30, 2006 | 08:48 AM
6 speed Sid's Avatar
6 speed Sid
Never had a problem with using the original one.
Old Oct 30, 2006 | 10:36 AM
Whiterock1's Avatar
Whiterock1
Thanx for the replies. Guess I won't worry about it for a few changes!
Old Oct 30, 2006 | 12:14 PM
UDRIVESLOW's Avatar
UDRIVESLOW
i change mine every time..
less than 5cents...i get mine free with the oil filters
i dont like drips....
udriveslow
Old Oct 30, 2006 | 12:53 PM
andreas g.'s Avatar
andreas g.
Default Something you my have missed....
C6 drain plugs are 14mm head and have no magnet tip. If you get yourself a C5 plug as I have, It's a 15mm head (better grip) and has the magnet at the end of the bolt. It's there to pick up metal pieces that are sheared off form time to time. Believe me no engine is free of that. Now as to why GM's wisdom has Failed to continue the use of this type of magnetic tip is beyond me. I have pieces on it at every oil change. Yes, I know there very small and seem insignificant, but why gamble. BTW it's about $4.50.
andreas G.
Old Oct 30, 2006 | 02:17 PM
JmpnJckFlsh
Originally Posted by andreas g.
C6 drain plugs are 14mm head and have no magnet tip...Now as to why GM's wisdom has Failed to continue the use of this type of magnetic tip is beyond me.
You missed it...there are no magnets on 05/06 C6s, but magnetic drain plugs are standard on 07.
No one can say the General doesn't listen to the customer...chrome OEM wheels ($$$$), magnetic drain plug. I have a magnetic drain plug I got for my 06, and have never installed it...not a big difference either way IMO.
Old Oct 30, 2006 | 02:57 PM
andreas g.'s Avatar
andreas g.
Not really, My 2002 C5 had a magnetic tip on the drain plug, and when I saw that my C6 didn't, I simply pruchased one for my C6 at the dealer, using the dealer part # from my C5. I reasoned that the thread size hadn't changed and it hadn't. The only difference being the head size of 15mm for the C5 and 14mm for the C6. This was in 2005 way before the 07's came out. I think your info my be incorrect.
andreas G
Old Oct 30, 2006 | 03:12 PM
Whiterock1's Avatar
Whiterock1
Intersting point. I had a magnetic tip on my 2000 Trans Am, as well. And generally a sliver or two on it. Think I'll go that way.
Old Oct 30, 2006 | 05:42 PM
JmpnJckFlsh
...I think your info my be incorrect.
I get no commission for lies or bs told on Corvette Forum...it's not profitable, so there's little incentive. Skepticism is healthy if it doesn't slam the door on your mind. Here, let me help you out:
http://forums.corvetteforum.com/show....php?t=1456470
http://forums.corvetteforum.com/show...tic+drain+plug
To Drain plug o-ring
Old Oct 31, 2006 | 11:46 AM
andreas g.'s Avatar
andreas g.
All I'm saying is that I bought one for my C6 in 2005 Using the C5 P/N, because the C6 didn't have one. That's it!
Old Oct 31, 2006 | 11:51 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
andreas G.
I also like to put a couple of wraps of teflon tape on the threads of the plug.
Old Oct 31, 2006 | 02:00 PM
JmpnJckFlsh
I've heard you say that before...some of you guys are not listening, and you're not getting any smarter, unfortunately.
Maybe the teflon tape won't do any harm, and you'll be OK, but why take the risk? Your reasoning is that the elastomeric o-ring needs to be backed-up by teflon tape???!! I'm outta' here...
