T1 Bars Squeaking
Old Oct 30, 2006 | 12:23 PM
ricatthebeach's Avatar
ricatthebeach
Default T1 Bars Squeaking
I installed a set of T1 bars a couple weeks ago. They just now have started squeaking. I took off the bushings, greased the insides of them theroughly and reinstalled them but... they still squeak. Any sugestions?
Old Oct 30, 2006 | 11:43 PM
kelp's Avatar
kelp
The T1 links have a little play in them, and rattle a good bit. I replaced mine with stock links. The force through them was so great it tossed off the self-tightening nuts. I therefore double-nutted them and locked tited them. No problems or noise since.
I you have a Z06, the rear bar will rub the muffler.
Old Oct 31, 2006 | 06:17 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
I took off the rear clamps where they go to the rear suspension frame and stacked one washer behind each bolt and them re-installed the clamps. Now there is no more squeeks. It moves the insulators away from the frame enough to stop squeeking, but not enough to effect the handling.
Old Oct 31, 2006 | 08:24 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
bushings should not be squashed. Not sure on C6 but on C5 you need 3 washers top and bottom to stop the from crushing the isolator (rubber bushing). they should rotate freely when tighten down. Use die-electric grease as it will last longer. Tubes in NAPA for 7 bucks.
Old Oct 31, 2006 | 11:21 PM
danielschulzjr's Avatar
danielschulzjr
where did you get the bars and how much$$. my local conection was lost with huricane Katrina
Old Nov 1, 2006 | 01:05 AM
ricatthebeach
Thanks for the tip. No Z06 but the exhaust isn't stock anyway.
Old Nov 1, 2006 | 01:07 AM
ricatthebeach
Fred Beans, about 700.00 shipped. Oh, they really work!
To T1 Bars Squeaking
