msd coils
Old Oct 30, 2006 | 04:13 PM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
Default msd coils
just a quick question, does anyone have the details on the msd coils for the ls2 ? longer duration ? hotter spark ? recommended plug gap, etc.
Old Oct 30, 2006 | 04:57 PM
andreas g.'s Avatar
andreas g.
Default The stock coils work...
Let me ask you this, If you start a forest fire with a match or blow torch,doesn't the fire still start? If you think increased voltage will make the flame propagation travel any faster across the quinch area in a highly compressed enviroment, I think you're mistaken. MSD makes quality products. There coils are just as good as factory. All of the great tunners in this country making 700+ HP blown cars use the stock factory coil. If they thought MSD coils would make a big improvement, believe me they would be using them. BTW there about $800 a set. That's half way to a cam and spring install which will make you a lot more power. My .02 cents
andreas g.
Old Oct 30, 2006 | 07:59 PM
timd38's Avatar
timd38
andreas g.
I looked at the price and thought the same thing.
Old Oct 30, 2006 | 11:06 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
MSD provides multiple spark.............. but you are fine with the stock units.
Old Oct 30, 2006 | 11:42 PM
I1uluz's Avatar
I1uluz
That is only an lower RPM's, higher the RPM less time for multiple sparks. Also I've made over 700RWHP using stock coils without an ignition problem. I think I could find something that would give me more bang for the buck than some purty red coils that will be hidden under the covers.
Old Oct 30, 2006 | 11:56 PM
NemesisC5's Avatar
NemesisC5
I Agree. Only good for looks if you have exposed fuel rails. No HP increase. I would love to have a set but $ spent best elsewhere.
Scotty
Old Oct 31, 2006 | 08:34 AM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
My experience with aftermarket coils are with a BMW, not a corvette. That being said, they were expensive and not worth the money. There was no noticeable improvement and in fact, I had to remove them because of faulty design which caused extreme radio interference. Sold them after 100 miles of use for about a third of what I paid for them. YMMV
Old Oct 31, 2006 | 08:26 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
if they are like their wires look out. Waste of money unless you have tons!
Old Oct 31, 2006 | 08:45 PM
Zig's Avatar
Zig
i don't know anything about their wires, i used to use Moroso Blue Max Spark Plug Wires.
the msd 6a box i used on my camaro was excellent, i was just wondering if their 'coil packs' were any good.
i never did find a good coil for that setup, in the camaro, i kept burning them up. the last one msd blaster, seems to be holding up but i had a problem of others 'boiling' and 'leaking' oil.
Old Oct 31, 2006 | 09:58 PM
Radical05's Avatar
Radical05
Default nope
Waste of precious HP dollars you will not see any difference using an MSD spark.
Old Oct 31, 2006 | 10:21 PM
9T4Z's Avatar
9T4Z
Originally Posted by Zig
i i never did find a good coil for that setup, in the camaro, i kept burning them up. the last one msd blaster, seems to be holding up but i had a problem of others 'boiling' and 'leaking' oil.
Funny you should mention that... burned up three Crane Coils on my Camaro... went back to something non-cdi coil... but the Crane Hi6 multispark was excellent...
Old Nov 1, 2006 | 08:52 PM
excessive81's Avatar
excessive81
ne one used them or we just bench racing here....they sure look cool!!
Old Nov 2, 2006 | 09:57 AM
I1uluz's Avatar
I1uluz
Blown LS2 based 402 (not in the C6), 717rwhp, no ignition based problems, granted that is only at 10psi. At higher boost levels it may become an issue and I will have to address that problem if and when it happens. But for 99% of this board I would think they are a waste of $$$$. Then again I think most appearance mods are a waste of $$$$.
Just like John's wire post, if the stock ones are working then there is nothing to be gained by buying "better" wires.
Old Nov 2, 2006 | 01:01 PM
Rphvette's Avatar
Rphvette
andreas g.
I love your answer man!
Bruce
Old Nov 2, 2006 | 03:38 PM
excessive81
but with the muti spark couldn't you possibly see better drivability down in the lower rpms.... i understand the if the wire works don't replace it idea but if you dont try it you can't say it don't work. i agree a 7 mm wire to a 8.5 will not add hp but this is diffrent if you ask me. i mean my headers worked but they are still in the corner
Old Nov 3, 2006 | 07:47 AM
I1uluz's Avatar
I1uluz
If you have unburned fuel left over from the first spark you have other issues. It can only burn so much, with newer design heads to burn much more effectively I don't see how there can by enough unburnt fuel to ignite again. Maybe on a untuned carb setup, but in closed loop I don't see it running that rich.
Old Nov 3, 2006 | 08:19 AM
mr 35th's Avatar
mr 35th
I say go ahead and buy em. Probably help you out that tm problem you have.
Old Nov 3, 2006 | 08:24 AM
Zig's Avatar
Zig
tm problem, more like traction problem.
To msd coils
