lean question... Important, please read!!!!
Old Nov 2, 2006 | 03:39 PM
Bluedevil3's Avatar
Bluedevil3
8th Gear
Default lean question... Important, please read!!!!
I have a 2006 C6 manual... About 6,000 miles ago I put the new Vararam intake, a vararam throttlebody spacer, and a B&B bullet exhaust, only those 3 mods (and a 160 degree thermo stat). Every since i put those 3 mods on my check engine light has stayed on. Today i got an OBDII code checker and there are four codes on, the P0171 code twice and the P0174 code twice. According the manual those codes mean my car is running "too lean"... My question is does this sound normal? And can i fix this without getting a tune? Lastly will this brake my car or void my warranty? Any input would be great!!! thanks in advance, Jarrod... (car runs great by the way)
Old Nov 2, 2006 | 03:52 PM
sallen619's Avatar
sallen619
Old Nov 2, 2006 | 04:10 PM
not08crmanymore's Avatar
not08crmanymore
I don't see how those three things would cause the car to run lean.None of them will void your warranty.Go to the dealer and see what's up.
Old Nov 2, 2006 | 04:18 PM
Dgatto's Avatar
Dgatto
Old Nov 2, 2006 | 04:22 PM
2008corvette's Avatar
2008corvette
I also have B&B Bullets, a Vararam intake and a throttle body spacer. I have had no problems.
Old Nov 2, 2006 | 04:48 PM
Bluedevil3's Avatar
Bluedevil3
8th Gear
ok thanks everyone... Iam going to make an appiontment with the dealer...
Old Nov 2, 2006 | 05:20 PM
chempowr's Avatar
chempowr
Will you let us know what is going when you find out?
Old Nov 2, 2006 | 05:28 PM
Miaugi's Avatar
Miaugi
Unless your dealer is "one of the good ones", I'm sure they will tell you those mods are the problem. Since you have been living with the codes for a while anyway, I would do this instead....erase the error codes with your code reader and see if they return....which I'd bet they do not.
I think this might save you some aggravation. If there is truely something wrong with your car or the computer, the codes will return and then I would take it to the dealer at that time.
Old Nov 2, 2006 | 05:32 PM
not08crmanymore
I think this might save you some agrevation. If there is truely something wrong with your car or the computer, the codes will return and then I would take it to the dealer at that time.
That makes sense too!!!
Old Nov 2, 2006 | 05:43 PM
VET4LES's Avatar
VET4LES
timd38's Avatar
timd38
Sounds like the right answer to me.
Old Nov 2, 2006 | 05:45 PM
Bluedevil3's Avatar
Bluedevil3
8th Gear
I made an appointment with the dealer for next week... I ve called every performance shop i can think of including Vararam. Unfortunately Vararam didn't answer but iam sure they will call me back, they are great guys. The shops I called said, do not make an appointment with the dealer, wait until you talk to Vararam and see what they say. Otherwise your car will be red flagged. So Iam going to wait until Vararam calls me back.. thanks again for all the input everyone, will keep posting... Jarrod
Old Nov 2, 2006 | 05:51 PM
cbrf4i1's Avatar
cbrf4i1
most likely you have leak in your intake area, my guess is it is after the maf, if that is the case, my money is on vararam spacer. if the code has been with you for 6000 miles, by deleting it and do nothing, it will just come right back, but i guess you have nothing to lose at this point. your maf is reading lower then what the o2 says, which cause your pcm to add additional fuel, that is why you are getting the lean code, this would be my best guess. good luck.
Old Nov 2, 2006 | 06:23 PM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
I agree an intake leak is the likely culprit.
Old Nov 2, 2006 | 06:27 PM
AutoCutter's Avatar
AutoCutter
That spacer is kinda shaky in its' design and I would try there first. You could have a bad O2 sensor, by the way.
Old Nov 2, 2006 | 07:32 PM
Brett Hunter's Avatar
Brett Hunter
Old Nov 2, 2006 | 09:39 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
If you want to know for sure take a sensor safe spray cleaner and spray it around the vararam spacer........ if the rpm go up when you spray.... you have found your leak.
To lean question... Important, please read!!!!
Old Nov 3, 2006 | 06:27 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
"P0174 OBD-II Trouble Code
Basically this means that an oxygen sensor in bank 2 detected a lean condition (too much oxygen in the exhaust). On V6/V8/V10 engines, Bank 2 is generally the side of the engine that doesn't have cylinder #1.
Note: This DTC is very similar to P0171, and in fact your vehicle may show both codes at the same time.
A code P0174 may mean that one or more of the following has happened:
[b]The MAF (Mass Air Flow) Sensor is dirty or faulty[/b[. Note: The use of "oiled" air filters (K&N, etc.) can cause the MAF to become dirty if the filter is over-oiled
There could be a vacuum leak downstream of the MAF sensor.
Possible solutions include:
...cleaning the MAF sensor.. ..
... take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
Inspect all vacuum and PCV hoses, replace if necessary
http://www.obd-codes.com/trouble_cod...gen-sensor.php "
Old Nov 3, 2006 | 07:39 AM
I1uluz's Avatar
I1uluz
Check around the bottom of the TB and the fresh air line going to the valve cover for leaks.
You can also use an unlit butane torch, while the car is running open it up just enough to get a good hiss and then move it around the area you think have the problem. The RPM's will increase once you find the leak. Also no mess from spraying all over the place.
Old Nov 3, 2006 | 10:03 AM
calemasters's Avatar
calemasters
You may have a vacuum leak down stream of the MAF sensor.
