Vararam is a very good cold air system. The air intake is centered in the grill opening, and air is ducted directly into the filter. One advantage is that no outside air flows into the engine compartment, so it stays clean. Dowside is that the shroud must be cut or swapped out, and a mounting bracket must be bolted to the car.
The Halltech Stinger is also very good, has a really huge, low restriction air filter. They offer a fresh air option that draws the air in through each side of the grille opening. However, the air is not ducted like the Vararam. I have one of these for sale if you're interested.
Other cold-air systems are the Hurricane, Calloway, and LPE systems --- I have no experience with them, but have seen favorable posts.
The Blackwing, K&N, & other systems are basically just improved filters. They won't do as much to keep the inlet air temps down, and offer no "ram air" effect. However, there are many that swear by them.
The Blackwing mounts like the stock airbox to the top of the radiator, and the Halltech just hangs there. Has anyone had a problem with the Halltech dislodging from the MAF?
the halltech does not move, even though it does not mount like the blackwing. The thing is massive and fits snug in the airbox chamber, resting slightly on the filter edge. I personally think they are all very similar, outside of the vararam. Buy whichever one you can find for the best price.
rothchilds,
Did you install the CAI option in addition to the intake?
not yet, but I figured I can do it later if I feel the need. I like the fact that nothing needs to be cut or modified in the engine to put this on vs the vararam, and I have not seen proof that one is definitively better than the other.
I am using the LPE cold air set up. I went with LPE because Lingenfelter has been doing vettes for a long time and they make a quality product. My second choice was the Callaway CAI or the Vararam.
I will be installing the callaway honker tomorrow and will let you my thoughts.
Please do I am very interested in any problems with install, and performance gains if any. I like the look of the Callaway, it has a stock appearance to it.
I have a Honker on my Z06 and C6 and they are quality pieces. Install is a bit laborious, especially on the C6, but the fit, finish, and customer service are all top notch with the Callaway unit. Plus, it draws in cool air from outside of the car.
I can't really comment on any performance gains as I haven't had a chance to put any real miles on either car since the installs (stupid weather).
I will definitely post my thoughts. Tomorrow CBRF41l (fellow forum member) will be lending me his time and expertise to accomplish the installation. As I have posted many times, I am mechanically challenged.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Originally Posted by deuce biglow
Which one do you guys like and why? HalltechSSM, Vararam, SLP Blackwing. Thnx
We installed the Honker on my 2005 auto and the vararam on my sons 2007 MN6. Both CAIs dropped the IAT temperature approximately four degrees from ambient temp.
With regard to the install, we installed both without removing the fan shroud and placed a piece of 1/8 inch plywood in front of the condenser so that we would not damage it. I used sheet metal screws and silcone to secure my honker to the fan shroud.
Is this true? I was going to buy a vararam but I didn't know I have to bolt it on.
Let me just start by saying... AHHHHHHHHHHHHHHHH!!!!!! Wait... AHHHHHHHHHHHH!!! The Shroud... AHHHHHHHHHHHHHHH!!!!!
The install was mostly completed by fellow forum member cbrf4i1 and my uncle both of whom more than make up for my mechanical ignorance.
Anyway, the instructions were not the greatest especially if you don't read them throughly. As a result, we removed the shroud, realized we had to measure before taking it out so replaced the shroud, measured, and again took off. Wow, that was a ****. Then had no clue about the rivet gun and could not figure out the deal with the screws as I didn't know that the rivet gun would actually cut these damn things to size. At this time, contacted fellow forum member beezeye through a PM. He immediately called us back and gave us invaluable advice. You can check out his post: http://forums.corvetteforum.com/show....php?t=1109197
O.K. the damn thing is on and it actually turned out GREAT! You don't want to know how long it took, but again it was a well done job. Took the car for a spin and realized it was all worth it... SOTP assessment
I am quite pleased with my Calloway Honker. I didn't measure the gains on a dyno but I could feel them. The throttle was more immediately responsive. There was a discernible increase in acceleration and the car sounded smoother after the install.
I had a shop do the install. It was the first one that they had done. I asked them to call Callaway and ask a tech how to do it. They did that. They did the install in about two hours with no problems. They were very complementary of the Honker and Callaway's verbal and written instructions.
