Wheel removal
Old Nov 12, 2006 | 10:17 AM
DHB820's Avatar
DHB820
St. Jude Donor '09
Default Wheel removal
I'm about to remove my C6 wheels so I can clean wheel wells for winter storage. Is there anything unusual about removing the C6 wheels I should know before I get started? Appreciate any input anyone has. Thanks.
Old Nov 12, 2006 | 10:24 AM
dennis50nj's Avatar
dennis50nj
no but when you put them back on, lift it right on the studs don't stop on the rotors, like some techs or should i say dicks and scuff scratch gouge the inside of the rim which is visible from the outside.
Old Nov 12, 2006 | 11:22 AM
Wayne88's Avatar
Wayne88
Originally Posted by DHB820
. Is there anything unusual about removing the C6 wheels I should know before I get started?.
Yes, they are attached to a Corvette.
Otherwise, they are the same as any other wheels.
Old Nov 12, 2006 | 04:22 PM
Miaugi's Avatar
Miaugi
Do not use impact tool to remove the lock nuts if you have them. Do not use impact tool to re-install any nut, be sure to use a torque wrench and to tighten in a star pattern.
To Wheel removal
