Some Interesting Power Comparisons
Old Nov 13, 2006 | 06:36 AM
yell03's Avatar
yell03
06C6FVR -
Nice video.
You must be powerhifting.
My car you hear the same 1-2 shift spinning, but my car only barks the 2-3, your spins it again like the 1-2
I have NO DOUBT your running what you say and I would also say your driving is worth 0.1-0.2.
BTW, how are you launching, I heard just a hint of wheelspin and then you were gone. No bogging at all.
Are you slipping the clutch and if so at what rpm?
Thanks,
Howard
Old Nov 13, 2006 | 10:15 AM
chempowr's Avatar
chempowr
Originally Posted by 06C6FVR
Well, here ya go!!...Believe it!! 100% STOCK
Here are the timeslips from my 12.23 @115.58 Run in stock form
http://home.houston.rr.com/dpickerin...d-1%20copy.JPG
And here is the video of the same run.!!
http://vids.myspace.com/index.cfm?fu...oid=1422971490
The video doesnt show the time, but look at the numbers on the car, 102, then check the timeslips!
Car has run a 12.15 with tune, DR and mufflers now
Daren
By the way howard, nice information... (sorry if i got your thread off topic...i just had to!! )
Great run! No catback as I thought I heard your revving down the track. Maybe it was the car next to you?
Old Nov 13, 2006 | 01:37 PM
06C6FVR's Avatar
06C6FVR
Originally Posted by yell03
06C6FVR -
Nice video.
Thanks,
Howard
I dont really remember, that was back in january...but i think then i was launching at around 2400rpm, slipping the clutch until the tires grabbed.
And no, there was no catback on the car, nothing but stock, I had the mufflers installed on 2/14/06, and this track run was 1-13-06
Daren
Old Nov 13, 2006 | 01:47 PM
SpinMonster's Avatar
SpinMonster
Originally Posted by DSOM Z51
I think that because these results aren't corrected for DA that they mean little to nothing.
You asked.
True but at a miniumum it gives you a best case scenario. 12.28 with headers and a tune can be done. Its something.
Old Nov 13, 2006 | 02:16 PM
vetteuphoria's Avatar
vetteuphoria
Interesting ...
The STOCK set-up is VERY good, although the exhaust note leaves alot to be desired.
Give Chevy credit, they gave us a great combo right pout of the box.
Howard
06C6FVR, Great run
Old Nov 13, 2006 | 04:39 PM
SoldSyclone's Avatar
SoldSyclone
Originally Posted by shurite44
Put on a vararam and go to the track. You guys may be surprised what a CAI does for the C6.
Mine gained 1 mile per hour
Stock best 12.85 @ 110 (good weather, 1.5 hr cool down)
Vararam best 12.89 @ 111 (cool but humid higher DA)
both backed up by 12.9's
Off to the track Fri to test my 1 7/8 Kooks they feel amazing but now the tires just spin so I assume I will go slower with stock tires!
I thought I would loose some TQ down low with the 1 7/8 and that would help my traction problems, no such luck.
Old Nov 13, 2006 | 04:55 PM
RBYCC's Avatar
RBYCC
You asked.
I guess I'm getting old...remember when all you got was a hand written cardboard slip, the size of a business card, with your ET and MPH.
It was so much easier back then to compensate with carbs, timing, plug heat ranges, maybe a collector extension and always the option of swapping gears based on your first few time trials before eliminations.
Technology you are the bane of the modern performance car...not so easy to DIY at the track !
So what's a DA?....used to be a haircut that my older brother wore !!!
Old Nov 13, 2006 | 04:58 PM
shurite44's Avatar
shurite44
Well on the C6 I had all my mods done at once, so I can not vouch for the vararam on the C6. But on the C5 I gained .3 and 3 mph.
Old Nov 13, 2006 | 07:45 PM
Brett Hunter's Avatar
Brett Hunter
Interesting results.
My tuner kept telling me to take off my aftermarket airbridge and go back to stock. Well I finally did and it runs better and produced better numbers than ever before.
Hopefully I will get down to HRP and run since our local track is already closed. This way I can back it up with something other than G-Tech times and recordings from the ECM.
I felt an improvement when I installed the aftermarket airbridge but it must have just been the lighter wallet.
Old Nov 13, 2006 | 11:25 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Would you care to disclose what aftermarket airbridge you had? You can PM me if you'd like.
