Questions
Old Nov 13, 2006 | 10:06 PM
Nightstalker Medic's Avatar
Nightstalker Medic
Default Questions
Just purchased a new 2007 LS-2 Convertible on Saturday.
Looking at adding the following to the Vehicle:
- Corsa Sport Exhaust System.
- American Racing full length exhaust system
- Granatelli MAF sensor for cold air intake
- Vararam LS-2 Throttle Body Spacer
- Vararam Intake
- 160 thermostat
Will there be any major PCM mapping that will have to be done??
Do they have a Predator Programmer for an 07 or can I get one for an 06 model year?
The build date for my car was 08/04/2006.
Thanks for the help.
Old Nov 13, 2006 | 10:13 PM
HITMAN99's Avatar
HITMAN99
In my opinion, forget the MAF, all you other planned mods are good. You can get a mail order tune from Corvettes of Westchester, he will fix you right up.
Old Nov 13, 2006 | 10:30 PM
shurite44's Avatar
shurite44
Everything but the MAF. Will not do anything for you and may cause you to throw some codes.
Old Nov 13, 2006 | 10:38 PM
Nightstalker Medic
Ok, forget the MAF. I was reading in some of the threads that there is a screen on the OEM MAF. Should that be removed like the MAF in the Z06s?
Old Nov 13, 2006 | 10:42 PM
shurite44's Avatar
shurite44
I have not taken my screen out. I don't think I will. Ask Spinmonster about that, I think maybe he took his out.
Old Nov 13, 2006 | 10:44 PM
shurite44's Avatar
shurite44
I recommend a dyno tune after you get the mods on. That runs around 4-5 hundred bucks. But you will get all the HP out of your mods that way.
Old Nov 13, 2006 | 10:46 PM
shurite44's Avatar
shurite44
Did you get the auto or manual tranny?
Old Nov 14, 2006 | 09:07 AM
Nightstalker Medic
I have the 6-speed. With the F-55 Suspension onboard.
Would the Predator Programmer be a bad investment??
Old Nov 14, 2006 | 09:53 AM
shurite44's Avatar
shurite44
Not sure on the predator. I have a friend that used one on the C5 and really liked it. I am not a mechanic so I lean more towards having someone else tune my car.
I think most on here like HP tuner for the labtop.
Old Nov 14, 2006 | 11:50 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Do Not Remove The Screen.....
Removing the screen is a BAD MOVE and will give you nothing in terms of HP and might just give you problems.
On the other hand.....A tune is way better than a hand held....
AND If we were to tune you now for instance...When the EFI LIVE Auto CAl comes out... I will be able to tune your car through e-mail and log it as well making the results near PERFECT! AND you never have to remove the pcm from the car......
Stay TUNED!
Chuck CoW
To Questions
