Still Timing Problems
Old Nov 14, 2006 | 08:21 PM
tony 63 vette's Avatar
tony 63 vette
Default Still Timing Problems
about a month ago I posted a timing issue. My06 A6 would pull 3 to6 degrees every dyno run. The dealership has replaced the knock sensors and even the P C M. Back to the dyno and nothing has changed has anybody else had this problem???????? I need help TONY
Old Nov 14, 2006 | 09:19 PM
glennhl's Avatar
glennhl
You've probably already have done this, but a search will show you that the computer will start pulling timing with 86F IAT or 216F Coolant.
Old Nov 14, 2006 | 09:27 PM
Hoonose's Avatar
Hoonose
Maybe you need to run 93 octane?
Old Nov 14, 2006 | 09:49 PM
tony 63 vette
always use 93 also tried booster I.A.T. and coolant temp were ideal
Old Nov 14, 2006 | 10:51 PM
SickRick's Avatar
SickRick
You getting any knock detection? What kind of MODS?
Rick
Old Nov 15, 2006 | 07:54 AM
HITMAN99's Avatar
HITMAN99
Have you had TM removed via tuning? What does your A/F mix look like?
Old Nov 15, 2006 | 08:16 AM
tony 63 vette
NO knocking no, no mods yet, tm removed, A/F a little rich
Old Nov 15, 2006 | 08:32 AM
HITMAN99's Avatar
HITMAN99
Hmmmmm, very interesting. I have had similar KR issues, but my A/F ratio is way lean, around 13.5:1.
I have also had a tune, with TM removed.
Old Nov 15, 2006 | 08:35 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
how are you determining it is pulling timing 3-6 degrees ?
are you using a timing light or relying on feedback from the computer ?
Old Nov 15, 2006 | 08:45 AM
tony 63 vette
dyno shows on every run @ about 2800rpm on up to 6500 HP drops as much as 20HP since it stays on low octane table car runs 12.85 best to a 13.5worst my tuner is stumped he has never seen it before
To Still Timing Problems
