Anybody replace a low beam bulb yet?
Anybody replace a low beam bulb yet? I have a question...
I'm about to switch out a stock low beam HID bulb for a 6000k HID bulb...BUT, I have a question first. Do I need to remove the bulb based on the 2 allen (or torx) screws shown in the pics on the link below or is there another way? There are warnings all over about the high voltage and I dont want to do anything wrong...
http://www.frontrunnermarketing.com/vette2.htm
Anyone have a manual that can check this for me? I just need to know how to pull the stock bulb out? I dont know if I need to remove the screws, or if this back plate is actually a cap that pulls off, etc...
Headlamp, Fog Lamp, Turn Signal Lamp, Side Marker Lamp Replacement - Front
Callout
Component Name
Notice: Refer to Fastener Notice in Cautions and Notices.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Headlamp Lamp Assembly Replacement
Preliminary ProcedureRemove front fascia. Refer to Fascia, Valence, Fascia Close Out Panel Replacement - Front Bumper
1
Front Fender Screws (Qty: 6)
Tighten 10 N·m (89 lb in)
2
Headlight Assembly Nuts (Qty: 3)
Tighten 6 N·m (53 lb in)
3
Headlamp Assembly
Caution: Refer to Halogen Bulb Caution in Cautions and Notices.
Tip
• Lift front fender up to remove headlamp assembly.
• Disconnect the electrical connector.
• Aim lamp as necessary.
• The front wheelhouse liner has an access door for bulb replacement.
Front Side Marker Lamp Replacement
Preliminary ProceduresRemove the front wheelhouse liner to gain access to the front side marker lamp. Refer to Fender, Insulator, Liner, Brake Caliper Cooling Duct Replacement - Front in Bumpers.
4
Front Side Marker Lamp Assembly
Tip
• Release the tab from the inside of the fascia and push outward to replace the lamp assembly.
• Twist the bulb socket and pull inward to replace the bulb.
Repeater Lamp Replacement (Export)
Preliminary ProceduresRemove the rear front wheelhouse liner to gain access to the repeater lamp. Refer to Fender, Insulator, Liner, Brake Caliper Cooling Duct Replacement - Front in Bumpers.
5
Repeater Lamp
Tip
Fog Lamp Assembly Replacement
6
Fog Lamp Bolts (Qty: 3)
Tighten 2 N·m (18 lb in)
7
Front Turn Signal Lamp Assembly
Tip
• Aim as necessary.
Document ID# 1507485
2005 Chevrolet Corvette
High Inttensity Discharge Headlamp Ballast, Bulb, and Cover Replacement
Callout
Component Name
Headlamp Bulb Replacement
Caution: The high intensity discharge system produces high voltage and current. To reduce the risk of severe shocks and burns:
• Never open the high intensity discharge system ballast or the arc tube assembly starter.
• Never probe between the high intensity discharge system ballast output connector and the arc tube assembly.
Caution: The high intensity discharge system produces high voltage and current. In order to reduce the risk of severe shocks and burns, the battery negative cable must be disconnected any time service work is being performed on or around the high intensity discharge system.
Preliminary ProceduresRemove and replace the headlamp assembly. Refer to Headlamp, Fog Lamp, Turn Signal Lamp, Side Marker Lamp Replacement - Front .
1
Headlamp Bulb Access Cover, Low Beam Cover
2
Socket Assembly, Low Beam Headlamp Bulb
3
Bulb Assembly, Low Beam Headlamp Bulb
Notice: When removing or replacing the arc tube, the arc tube must not contact the side of the headlamp housing or the bulb shield. Damage to the arc tube may result.
4
Headlamp Bulb Access Cover, High Beam Cover
5
Bulb Assembly, High Beam Headlamp Bulb
Front Turn Signal Lamp Bulb Replacement
6
Bulb Assembly, Front Turn Signal Lamp
Headlamp Ballast Assembly Replacement
7
Screw, Ballast Access Cover
Tighten 3 N·m (27 lb in)
8
Cover, Ballast Access Cover
9
Screw, Ballast
10
Ballast Assembly, Headlamp
Document ID# 1503854
HOPE THIS HELPS..
UDRIVESLOW
Callout
Component Name
1
2
3
Headlamp Assembly
Tip
4
Tip
5
Repeater Lamp
Tip
6
7
Tip
• Aim as necessary.
Callout
Component Name
1
2
3
4
5
6
7
8
9
Screw, Ballast
10
HOPE THIS HELPS..
UDRIVESLOW
