proposed mods
Old Nov 23, 2006 | 04:23 PM
knkali's Avatar
knkali
Default proposed mods
What do you guys think of these mods to my 06 A6.
Lets keep cost out of the equation. Instead, I would like to know if I am on the right track for creating a bit more torque through out the rpm range with little to no drivability/durability problems. I have decided to not go FI and do not want to go into a cam replacement. I am trying to have my cake and eat it too. I am not looking to go from 100 to 185 faster. Instead I want to go from idle to 100 faster, reliably, with stock like drivability. The car will not see the track just street.
Fast intake
AFR 205 heads
1.85:1 rocker arms
long tube headers with cats
tune
Questions:
What kind of HP/torque #s do you think I will achieve?
will I lose any power in certain rpm ranges?
will idle remain stock?
Will valve train noise be that much louder than stock?
will headers generate that much more cabin heat than I already have now.
Will headers with stock mufflers be very much louder than the stock set up? I like the stock sound.
Will I PASS Ca smog either via PCM or sniffer?(I'll take my chances on a visual)
Any ideas or potential problems that I have over looked?
Thanks for your input.
Old Nov 23, 2006 | 04:30 PM
bunk22's Avatar
bunk22
I'm not an expert on this matter since I don't have aftermarket head or cam but I do have the 1.85 rockers. Why not just go with a nice mild to med aftermarket cam? I really think the gains would outweigh the rockers. My rockers gave me good gains on paper but nothing at the track......thus far.
Old Nov 23, 2006 | 04:46 PM
knkali's Avatar
knkali
It wont see the track. I hope that I will feel an improvement though. I really dont want to tear too far into the motor if possible.
Old Nov 23, 2006 | 05:26 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
I would vote cam over rockers. In every car that I've seen(non Corvettes as well) overall power increase was better with a cam than rockers. Rockers also have more moving parts prone to failure. I've seen too many rockers, of various sizes and applications fail and cause motor damage, to ever put a set on any of my cars. A properly matched H/C package will really impress you. If you size them correctly, they can be very streetable and reliable. As well as not drasticly effect fuel economy. Good luck.
Old Nov 23, 2006 | 05:53 PM
knkali's Avatar
knkali
just when I said to myself no cam you make me doubt myself.
Old Nov 23, 2006 | 06:18 PM
k0bun's Avatar
k0bun
I didn't mean to make you doubt yourself. Just sharing my experience and opinion. On a previous vehicle I was literally hours away from ordering a set of rockers when my builder/tuner advised against it based on some sets that he had seen on customer's cars. So I decided not to go with them. A few weeks later several reports started coming out about faulty rockers causing head and motor damage. This was with a set from a very refutable company. Now that application was way different than the C6 but enough to waver my opinion of rockers. But by all means get several opinions. If I were you I'd ask some members who have done rockers and see how they feel. Wasn't there a thread about bad rockers a few weeks back? Well whatever you decide, just make sure you research it thuroughly and go with someone you trust. These motors are expensive to replace. Good luck.
Old Nov 23, 2006 | 07:23 PM
johnodrake's Avatar
johnodrake
Moderator
Here is my .02
Fast intake - Should make good power but you must cut/mod the firewall. I will just use a ported intake
AFR 205 heads - Good rep, good power also check out LPE
1.85:1 rocker arms - I have heard to many tales of failure/damage for me to use them. It changes the valve train geometry which can't be good.
long tube headers with cats Good power and torque, but emissions inspection problems.
tune - yeah buddy
I will add a cam to my mod list. There are some good reports of cam changes that make really good power on the low end/ under the curve and have limited/no effect on drivability.
Old Nov 23, 2006 | 10:31 PM
k0bun's Avatar
k0bun
Originally Posted by johnodrake
Here is my .02
tune - yeah buddy
Old Nov 24, 2006 | 12:31 AM
knkali's Avatar
knkali
arrrg just when i thought i had it, i start to soften on the cam idea
Old Nov 24, 2006 | 12:41 AM
k0bun's Avatar
k0bun
Where are you located?
http://forums.corvetteforum.com/show....php?t=1549090
This will most likely be in my car's future.
Old Nov 24, 2006 | 12:54 AM
SpinMonster's Avatar
SpinMonster
Best advice for anyone:
Stop trying to come up with the killer combo formula and go to a tuner and drive a head/cam car with the mod package you can afford so you dont come up with surprises.
Old Nov 24, 2006 | 09:35 AM
knkali's Avatar
knkali
Good advice but hard to do or find cars to compare
Old Nov 24, 2006 | 09:52 AM
HITMAN99's Avatar
HITMAN99
Listen to Spin. You don't need to find the "perfect" combo, just a good one ---- and believe me, there are MANY good ones.
I have run a heads-only combo before with aftermarket rockers, but they were the stock ratio (Yella Terra's). I would not have fooled with them except I got them for a ridiculously low price, and I already had the head install scheduled. My installer gave me a great price for installing the rockers at the same time, so I said OK. Still, I was surprised at how much time and effort he took to get the rocker geometry just right. If I had to do it over again, I wouldn't bother.
In my opinion, if you are going to spend the money for AFR heads and a FAST intake, it's foolish not to also do a cam. Pick a nice middle of the road cam like a 224/228 with .580" lift, and you should be able to get a mail order tune that will be real close to optimal.
To proposed mods
