From: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
how does the C6 breath?
The air that enters through the front grill seems to all get directed into the radiator as the sides are sealed off. Also what are the plastic pieces covering (located right behind the grill) to the sides of the radiator. Halltech makes a shroud with screened ports (where the plastic pieces are) to allow air to enter to the filter. So back to the initial question where does the C6 draw its air from in its factory configuration?
Well wherever it draws from it's much better then the stock intake on the GTO! With the GTO the plastic airbridge would always be hot to the touch. The other day I put a hand on my Halltech and the bridge was nice and cold after a drive.
The stock C6 intake pulls air from the engine compartment. The shroud directs the air coming in from the grill to the air conditioner condenser and the radiator.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
If you stick your fingers through the grille and poke at the blank plastic sheets on either side of the radiator opening, you will find that they are open at the top, and bleed air into the compartment above the radiator feed where the aircleaners live. Also, from underneath the car, there are a pair of fairly large openings (about 6" square each) at the bottom, behind those blank black plastic pieces, that allow air flowing under the car to flow up into the air cleaner space. All of these taken together DO feed enough air to the aircleaners to allow the engine to make 400 SAE net horsepower.
There can't be much cool air reaching the stock filters, every brand of CAI seems to give around 15 RWHP on the dyno, probably more in a real world airflow situation.
every brand of CAI seems to give around 20 RWHP on the dyno, probably more in a real world airflow situation.
I don't know about 20rwhp from EVERY brand...I can maybe see the Vararam giving some nice gains once the car is moving but few if any CAIs are legitimately/safely giving 20rwhp while on a dyno.
I'll edit my original post to 15RWHP, I looked up my dyno sheets.
I'm talking about the true Cold Air Intakes, not the filter or air box mods. If it draws fresh air from the grille opening it's a CAI, anything else is still using warmed air thats been thru the radiator and around the motor. My Lingenfelter CAI gave as much peak HP as the LT headers. Dyno'd with cat back @ 350/346, with headers @ 365/362, with CAI @ 379/371.
I wish there was some way of simulating the airflow to the intake @ 145MPH in 4th, fans on a dyno can't come close.
A Temporal Anomaly ? ? ? ? ?
Is the CF having a "clock" problem?
My reply to Brett Hunter's post really was made at about 2:21 pm EST today, but his is time-stamped 2:29 pm, so my reply is ABOVE his post .
Is today the day the the earth's magnetic field is flipping the North and South poles, or is there some other explanation for this temporal anomaly ? ? ? ? (Captain Picard - the sensors are acting strangely . . .)
- - - - on edit - - - - still having strange results - - - -
There can't be much cool air reaching the stock filters, every brand of CAI seems to give around 20 RWHP on the dyno, probably more in a real world airflow situation.
Actually the stock location does a pretty good job of getting ambient air. It is better than the bottom breathers except for the time it takes to get to ambient. All of the graphs that I have seen and the one log I have show the IAT on the cut shroud to be at best +10 degrees over ambient. Where the stock filter will get much closer to ambient (the Halltech gives the same results as stock maybe slightly better).
If anyone has data to prove otherwise please post it. I have ask for data proving the bottom breathers lower the IAT in several threads over the years and I have never received a response. Most of these threads had the manufactures responded in them but my question always is ignored. Like I stated earlier I have limited logs of a bottom breather so I am relying on others to show the benefit as far as IAT is concerned.
As you can see from the below chart the IAT does get within 3 degrees of ambient at 70 mph with the stock filter. BTW ambient was 65 degrees and the lowest recorded IAT was 68 on this run. This is probably a worst case scenario for the stock setup since prior to this scan there were 8 WOT runs over an hour long scan. So this shows the stock setup after over 1 1/2 hours of running with the first hour being very hard driving.
I know, I responded with the first porst at 12:29 CST before haljensen responded to LS1LT1 but it shows 1:29 CST
If you were to put a light under the car, at the back of the front fascia and look down from the engine compartment, you will see openings behind the blanked off areas.
If you were to cut your shroud ala Halltech, and view from the front, you would see clear space to the firewall.
The open shroud will allow added outside air into the filter area, but it's not as if it were entering a sealed plenum !
Originally Posted by D. Togo
. . . Why do you think GM made the intake system so restrictive, for emissions?
Others who have just drilled a few holes in the blank black plastic reported more bugs and dirt and leaves and other junk in the air cleaner area. Given the LARGE openings at the bottom, and the fact that the air has to rise UP to get to the air cleaners, I believe that the goal was to keep solid debris from challenging the air filters as much. I don't think that the air path is really that restrictive, when you put the car on a lift and examine it from below.
If I make it to the Corvette Corral at Sebring in March, I will ask some Corvette engineers the real reason.
on edit - - - more temporal anomalies - - - this is a response to D. Togo's post below - - -
I agree about minimizing the bugs and dirt from getting to the filter. That was my main gripe with the Vararam. They could have at least screened the opening like Halltech does. With the stock airbox and filters extra dirt/bugs would be a real problem but with the "right there" open access to the Halltech Stinger that would not be an issue at all. You can even easily remove the filter for cleaning.
Clevite, If you asked the Corvette engineers at the Corvette Corral about the intake system that would be great. Im sure however you will be so excited to be there you will forget.
Great post CleviteKid thank you. Why do you think GM made the intake system so restrictive, for emissions? Those plastic pieces IMO should definitely not be there. I have the Halltech Stinger SSM (LOVE IT!) and will be purchasing the Halltech Cold Air Induction to shoot some fresh cool air right to the filter. I will have to ask Jim Hall about the programming as its suggested after installing the CAI but not with the Stinger alone.
Ah yes, data trumps opinion every time. Thanx for your contribution.
Thats why I posted the Dyno RWHP gains with the Lingenfelter, I've never data logged the intake air temps but I got 14RWHP just adding the CAI for $350.00.
