Vararam
Old Nov 29, 2006 | 05:49 PM
Dan C4-C6's Avatar
Dan C4-C6
St. Jude Donor '06-'07
Default Vararam
I have done a search on intakes but I still have some quick questions! Is the Vararam the best intake for performance? Also how is the quality and fitment?
THANKS GUYS
If all goes well I plan to get the precut shroud, the intake system, and the throttle body spacer. And my 07 has never seen rain so I don't have to worry about water ingestion.
What is the 2nd best c.a.i (performance wise)?
Old Nov 29, 2006 | 05:54 PM
not08crmanymore's Avatar
not08crmanymore
YES.AND FINE.
Old Nov 29, 2006 | 06:18 PM
shurite44's Avatar
shurite44
I would do a search and read them all very carefully. I have one, but I am a little concerned about the fitment at the moment.
Old Nov 29, 2006 | 06:44 PM
C5pilot's Avatar
C5pilot
Do a search, and prosper.
Old Nov 29, 2006 | 09:11 PM
Ginny C6's Avatar
Ginny C6
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
I am in the middle of an install right now, and so far I'm not impressed with the fitment, but I'm not done yet. One piece of advice.. get someone to help that has experience or pay a shop that has done them before. Kevin
Old Nov 29, 2006 | 10:10 PM
SS MPSTR's Avatar
SS MPSTR
..and don't cut through your condenser.
Old Nov 29, 2006 | 11:12 PM
Dan C4-C6's Avatar
Dan C4-C6
I am definitely concerned with the fitment issues. An intake that leaks is no good. I wish the quality was as good as the performance gains.
THANKS GUYS
I don't know if I am still going to buy the Vararam. I want to do a little more research on other intakes.
Old Nov 30, 2006 | 01:18 AM
SS MPSTR's Avatar
SS MPSTR
The intake doesn't leak...at least mine doesn't. The cutting and fitting the intake assembly through the shroud is the hardest part of the install. Other than that, it is a great product.
Old Nov 30, 2006 | 01:40 AM
BernieR's Avatar
BernieR
THANKS GUYS
Hi Dan..here's my experiences with intakes for two C-6's.... for what it's worth..
1) I put a "HURRICANE" INTAKE on my Black '06 Z-51 6-spd.....it was a PIA to put in but the fitment after installation is good, although i'm not thrilled about the instructions to wash and re-oil the "green Stuff' filter element every 5000 miles. I have 22,000 miles on my '06 and have cleaned the element once. Fitment is excellent and rseults (RWHP with Random Tech headers, high flow cats, X-pipe and "noisy" Corsa Sport exahust +160 F T-stat, B/P'd injectors but no tune yet....are excellent.
2) I put a Hall Stinger on Terry's Monterrey Red '07 A-6 coupe and it was easier to install, plus the qulaity (NOT flimsy like the HURRICANE or VARARAM) was excellent. Results TBD since this car is currently a "garage queen".
3) Have seen other cars (various C-5's) with VARARAM intake and while results at the dragstrip were good, ease of installation, quality of construction and fitment were problematical, to say the least, IMHO. I'm told ,but haven't seen, that VARARM is much improved for the C-6 application. But since I drive in any weather, I'm concerned about the "0.1%" chance of ingesting H2O...so no VARARAM..I think I'll probably dispense with normal aspiration, in April '07, and get a "wheezer".i.e. a PROCHARGER Intercooled supercharger when the '06 C-6 software is available.
Best Regards, Dan....Bernie
Old Nov 30, 2006 | 09:29 AM
BC Bob's Avatar
BC Bob
Had to drill new mounting holes in the Vararam, notched the plastic radiator cover and shaved the rubber side-mounted blocks to make the two halves fit together tighter. If I had to do it again, probably would have bought another brand of CAI.
Old Nov 30, 2006 | 11:22 AM
ShockerRacing's Avatar
ShockerRacing
I really believe that if you install the Vararam correctly you won't have any fitment issues or problems.
http://www.shockerracing.com/phpBB2/...pic.php?t=1380
Old Nov 30, 2006 | 07:20 PM
BC Bob's Avatar
BC Bob
It was installed correctly. First time was Saturday. Took it apart Sunday and reinstalled it again. That's when I made all the modifications to make it fit better. When I installed it the first time, there was no adjustment left on the red mounting bracket. The Vararam still was an inch higher than the TB and it hit the hood liner. Second time, I drilled new holes in the Vararam and notched the radiator cover. Gained about 3/4". What I plan to do next is eliminate the accordian coupler and replace it with a smooth silicone coupler. The accordian coupler will cause unnecessary turbulence with the misalignment. We'll see what happens. I'm not real happy with the original fitment.
Old Dec 1, 2006 | 03:11 PM
Dan C4-C6's Avatar
Dan C4-C6
Just a quick question, what is the second best c.a.i (performance wise)?
Old Dec 1, 2006 | 03:48 PM
andreas g.'s Avatar
andreas g.
Default You get what you pay for...
I've seen them on C6's, and in my opinion there the cheapest looking air intake on the market. There filter is junk, and as for a RAM effect,
what effect can you have when the imcomming air hits the filter element? NONE. Simple physics. The only way it could possibily work is whith no filter element at all. My opinion.
To Vararam
