help w/codes please
Old Dec 5, 2006 | 11:55 PM
Spit's07C6Z's Avatar
Spit's07C6Z
Default help w/codes please
I installed the Vararam on the wife's C6 tonight and during her test drive her CEL came on. The codes were P0220 P0222 P0223. I know those are Throttle Position Sensor 2 Circuit, low and high voltage, but I would like to know what those codes mean? Do I need to replace something or what do I need to do? Thanks.
Old Dec 6, 2006 | 12:09 AM
cbrf4i1's Avatar
cbrf4i1
you might want to double check all the hose clamps are tight, specially after the maf.
Old Dec 6, 2006 | 07:07 AM
gtodoug's Avatar
gtodoug
P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
Is all the wiring plugged up and everything?
Dougie
To help w/codes please
