Who else had a problem installing their Hurst shifter?
Old Dec 6, 2006 | 12:03 PM
Joecooool's Avatar
Joecooool
Jax Events Coordinator
CI 3-4-5-6-7-8-9 Veteran
St. Jude Donor '03-'08
Default Who else had a problem installing their Hurst shifter?
I've installed about thirty of them on Forum members C5's and never had a problem.
I just installed on on my C6 and had one. The bolt that holds the **** to the shifter was not threaded correctly and my bolt snapped off while tightening it. I mentioned that in this thread - http://forums.corvetteforum.com/show....php?t=1566110 and two others said they had the same problem.
I emailed Hurst three times and the only response I got back was a blank reply sheet.
Perhaps it was just the last batch, but how many others have had this problem?
By the way, West Coast Corvettes is a stand up vendor, they are overnighting me a new shifter.
Old Dec 6, 2006 | 02:02 PM
high test's Avatar
high test
Default hurst shifter
yes had the same problem screw would only go in 1/2 way instead of forcing it i replaced the screw problem solved
Old Dec 6, 2006 | 04:13 PM
whitesox05's Avatar
whitesox05
yup - it is the screw and not the shifter. Although the instructions state that you can use the same one you cannot. I believe it is either a #10 or #8 and can be picked up at any hardware store for pennies...
To Who else had a problem installing their Hurst shifter?
