Changing Gears when cold
Old Dec 8, 2006 | 04:55 PM
vette-oholic's Avatar
vette-oholic
Default Changing Gears when cold
I know people have posted that the shifter is a bit rough before it warms up, but is cold shifting actually bad for transmisison??
Old Dec 9, 2006 | 04:41 AM
magredcpe's Avatar
magredcpe
why....sell the car
Old Dec 9, 2006 | 08:03 AM
excessive81's Avatar
excessive81
no..
Old Dec 9, 2006 | 12:10 PM
calemasters's Avatar
calemasters
Default is cold shifting actually bad for transmisison??
Originally Posted by vette-oholic
I know people have posteed that the shifter is a bit rouhg before it warms up, but is cold shifting actually bad for transmisison??
Not as bad as doing 6,500 rpm in 1st gear, at 55mph with a cold engine, because you did not want to cold shift.
Old Dec 9, 2006 | 05:54 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Don't bang your first few shifts and you won't do any damage. I only see this on mine shifting 1-2, and 2-3 with the temperature below about 60 deg. I move the shifter slowly into neutral, pause, and then into gear...it seems to help some with the synchro and gear engaging easier. I have tried double-clutching...that also seems to help some, but double-clutching is giant PITB even if it's only for a few shifts.
After a few shifts, the transmission fluid gets over about 60-70 deg, and it'll shift easier. By the time your engine oil temperature is at normal operating level, your transmission should shift like butter.
Old Dec 11, 2006 | 09:50 AM
stabori's Avatar
stabori
St. Jude Donor '08
Same here. On these cold 30 degree mornings, just take it easy for the first couple of shifts. then no problems. No John Force takeoffs.
To Changing Gears when cold
