DTE Diff brace, is it worth it?
Old Dec 17, 2006 | 08:45 AM
Stingray55's Avatar
Stingray55
Default DTE Diff brace, is it worth it?
Will it bolt up to C6 diff, Has anyone installed one on their diff ?
Is it worth the money, Is it needed for street car with 4:10's ?
Thanks in advance.
Old Dec 17, 2006 | 09:02 AM
SickRick's Avatar
SickRick
Yah, it's probably worth it in any case - but especially if you start adding power. Will it prevent a mishap if you light em up, get wheel hop and stay on the pedal? Most likely not - but we should know better than to let that happen anyway.
At my level of mods, it (and a hardened output shaft) was cheep insurance while I had the drivetrain out to do the clutch...
Rick
Old Dec 17, 2006 | 09:34 AM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Rick
If you've added power enhancers like Rick and I have (Maggie/Procharger) adding the DTE kit is indeed cheap insurance.
Old Dec 17, 2006 | 01:41 PM
snappy28's Avatar
snappy28
Cruise-In VIII Veteran
A better question may be, has anyone ever broke their differential while using the DTE brace?
Old Dec 17, 2006 | 03:06 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
That IS a good question. I have one on my C6 and had one on my C5 and haven't broken my rear [crosses fingers].
Old Dec 17, 2006 | 08:37 PM
c6speedjon's Avatar
c6speedjon
where u on a drag radial or a slick when you had the brace on it? did you launch your car hard?
Old Dec 17, 2006 | 09:20 PM
Z06Gates's Avatar
Z06Gates
Default brace?
I am new to the forum. What is this DTE brace you are talking about?
Old Dec 17, 2006 | 09:31 PM
snappy28's Avatar
snappy28
This thing:
http://www.corvettegarage.com/produc...-corvette.html
Old Dec 17, 2006 | 09:51 PM
Z06Gates's Avatar
Z06Gates
Default DTE brace
Thanks for the link. Cool site!
Old Dec 17, 2006 | 10:03 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
If you drag race for long enough, you're going to break things. Brace or no brace. The only thing that brace is going to do is limit the carnage. It should keep you from damaging your transmission too. But this diff busted from the inside.
These were posted on the C5 forum some time ago. I copied and kept them as a constant reminder of what can happen on the drag strip. Brace or no brace.
Old Dec 18, 2006 | 07:21 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I've run on both DR's and ET Streets. I don't launch that hard - 1.70 is my best in my C6 and 1.6 on my C5.
From what I've seen at the track and read here, I think the key to breakage is controlling wheel hop. I've never experienced it on DR's or ET's. I don't race on or spin my EMT tires, they are too darn expensive! I've watched a few guys blow rears on EMT's at the track due to wheel hop.
Old Dec 18, 2006 | 08:00 AM
EuroRod's Avatar
EuroRod
Is the brace an easy install? Or is it necessary to drop the rear cradle?
Old Dec 18, 2006 | 03:19 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
If you're going to be drag racing on some sort of slick tire, then absolutely!
If not, then I don't think you'll need it. A hardened O.S. as mentioned above is a good idea as well.
I broke bad in my C5Z on a drag radial dead hook once. Diff housing, trans housing,etc...
Went w/ DTE brace, hardened O.S. & Rodney trans & never broke again!
Haven't heard of anyone breaking w/ one installed either. Even if you were to break, the brace will severely reduce the number of parts that DOES break!
Ron
Old Dec 18, 2006 | 04:37 PM
CYA-Vett's Avatar
CYA-Vett
That is not good news, the rear broke before the output shaft, that is a stock output shaft shown in the pic
Old Dec 18, 2006 | 10:40 PM
30YR W8T's Avatar
30YR W8T
The DTE instructions recommend that you drop the cradle to ease the installation. I did not do this when I installed mine, but it was a PITA and I left some skin up in the transmission tunnel. The hardest part was installing the top rear strut rod mounts on the transmission, especially trying to attach the wiring harness strap on the passenger side. However, it can be done without dropping the cradle.
Old Dec 19, 2006 | 01:33 PM
SpinMonster's Avatar
SpinMonster
Aintqik's diff broke with just about everything inside still good and he had a stock output shaft.
The above pictures are from a C5 not a C6 brace. The C6 version doesnt have the bottom two diff to transmission supports. The two lower diff mount arms have been said to be the reason you dont need the two lower ones. The ring that goes around the diameter of the side covers is also much smaller giving little support.
These braces arent keeping anything from breaking. Cars with no brace have similar breakage.
Few if any people take their car to the track after suffering big damage so there is little evidence to support what it does or doesnt do.
Old Dec 19, 2006 | 03:13 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Isn't the shaft above the input shaft? I think the output shafts run parallel to the ring gear, not perpendicular..
DTE has posted a ton of information why they say the brace helps, if the original poster is still looking at this thread, might be a good idea to search for posts by DTE Engineering.
DSOM, do you recall that type of launch caused that carnage? Was there wheel hop? Was it a clutch drop off the rev limiter? I'd like to know - so I can avoid that type of launch!!
To DTE Diff brace, is it worth it?
Old Dec 19, 2006 | 06:55 PM
'06 Quicksilver Z06
Sorry, I don't know. And I can no longer locate the thread.
Old Dec 19, 2006 | 07:19 PM
Stingray55's Avatar
Stingray55
original poster is still looking, and still learning.
Thanks for all your imput.
Old Dec 19, 2006 | 07:54 PM
SpinMonster
I think the point was that the brace was in place and there was still a break. Other tuners have some input on the topic without bias. Maybe you should call around. Other opinions can be valuable, even the manufacturer I guess.
