Do you use wheel locks?
Old Jan 3, 2007 | 04:13 PM
ShockwaveGT's Avatar
ShockwaveGT
Default Do you use wheel locks?
I posted in the wheels board, but figured here would be more C6 specific.
I have a C6 with aftermarket wheels and I was curious if others with aftermarket, or even factory, wheels use wheel locks to prevent theft.
If so, what kind?
Thanks.
Old Jan 3, 2007 | 04:18 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Glock Model 27. Wheel locks slow them down about 10 seconds. If they have access to your car and the time, your wheels are gone locks and all.
Elmer
Old Jan 3, 2007 | 04:23 PM
ShockwaveGT
Elmer
Right, I realize that anyone who knows what they are doing and really wants them can still get them, or just take the entire car...
But locks could slow down a more ameature theif or prevent them from bothering...
Old Jan 3, 2007 | 04:30 PM
Evilways's Avatar
Evilways
I used locking lugs for a time....was a pain to keep up with the key lug, and if you have a good set, not an autozone set, the keys can be really difficult to replace. I had to use alot of force and an air wrench to remove my last set after the ket was lost. The "autoparts" stores sets are easy to defeat, as there is only a few different keys for all the ones they sell. A good theif makes a small investment by buying one of each type.
Old Jan 3, 2007 | 04:35 PM
dennis50nj's Avatar
dennis50nj
no locks keep it in sight or locked in garage
Old Jan 3, 2007 | 05:09 PM
Evilways's Avatar
Evilways
Someone should do an aftermarket tire pressure sensor with a proximity alarm, so if your wheels go too far away from your car, your alarm sounds and one inside the tire does as well so you can track them down....
Old Jan 3, 2007 | 05:10 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
I use the GM locks made by McGard. Hopefully they'll move on to an easier target.
Old Jan 3, 2007 | 05:41 PM
c6silverbullet's Avatar
c6silverbullet
Old Jan 3, 2007 | 06:11 PM
VET4LES's Avatar
VET4LES
I have locks that I bought at Auto Barn that match the look of the lug nut. I think they are Gorilla.
Old Jan 3, 2007 | 07:57 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
I use McGard tuner lugnuts, which aren't locks per se, but are thinner lugnuts that need a special chuck to remove. I do it to keep from messing up the lug holes though, and not for security. The only time my Vette stays away from home and outside for any length of time is in the Delta employee lot at the airport, which has the same security as the airfield.
Old Jan 3, 2007 | 08:04 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
No locks
It does not leave my sight !
Old Jan 3, 2007 | 08:17 PM
crabman's Avatar
crabman
No locks, hoping someone will steal the stock wheels.
Old Jan 3, 2007 | 08:30 PM
burtonbl103
Now thats a good one
Old Jan 3, 2007 | 09:22 PM
saplumr's Avatar
saplumr
No locks for me anymore. Couple of years ago I misplaced the lock lug at the wrong time and you can't get a replacement from the manufacturer.
Old Jan 3, 2007 | 09:32 PM
VET4LES's Avatar
VET4LES
Not a problem. You remove them like the thieves do. Beat a slightly smaller socket than required on the lock and unscrew it.
Old Jan 3, 2007 | 09:37 PM
saplumr's Avatar
saplumr
That's what we did, no other choice. But...that was enough for me, never again.
Old Jan 3, 2007 | 09:42 PM
easyrider13's Avatar
easyrider13
I installed McGards.
To Do you use wheel locks?
Old Jan 3, 2007 | 10:01 PM
SSJCreeper's Avatar
SSJCreeper
Every lug is a Gorilla lock... 20 of em! I'm not taking my chances... even though the car doesn't leave my sight. Had a scare in my youth where some SOB decided to be cute and loosen all the lugs on a convertible I had. Wheel flew off the car on a busy highway at 65mph.
Needless to say the rear rotor and fender was TOAST. Had to change out my pants after that too.
Old Jan 3, 2007 | 10:13 PM
AP's Avatar
AP
Not a bad idea ... but I feel bad for any tire shop that does work for you ...
Old Jan 3, 2007 | 10:44 PM
rothchilds's Avatar
rothchilds
no locks, the car is so low that more than likely they will damage something else when trying to get them off, so I might as well make it easy for them so they get the hell away from my car faster.
seriously though, I've never had a problem with wheel theft. Most wheel theft is someone that knows someone, and is pissed at them, or they are trying to scam insurance. I've seen a lot of that in my short time.
