Vararam install questions
Old Jan 3, 2007 | 06:13 PM
Stingray55's Avatar
Stingray55
Default Vararam install questions
How difficult is the install? What tools do I need ?
Also ordered pre cut shroud with spacer, Thanks.l
Old Jan 3, 2007 | 07:38 PM
User 81424's Avatar
User 81424
ttt
Old Jan 3, 2007 | 09:26 PM
dennis50nj's Avatar
dennis50nj
very easy it is outlined in the instructions what you need
Old Jan 3, 2007 | 09:44 PM
OCCOMSRAZOR's Avatar
OCCOMSRAZOR
It took me about two hours. (Of course about one hour was taken up as I pounded my head against the wall AFTER I nicked a teeny, tiny little $500 hole in my air conditioner condensor.)
Old Jan 3, 2007 | 11:13 PM
chemten's Avatar
chemten
after you complete it, you will realize how unnecessary removing the shroud is. it took me about 45mins to just cut the hole. take it slow, cut towards the front of the car(away from the condenser). use a piece of plywood or MDF between the shroud and the condenser to help protect in case of an accident. i just used a sharp utility knife and it cut like butter after getting it started. my only advice is don't rush and be patient.
edit: one other thing. i used white-out to trace the template for the cutout.
Old Jan 4, 2007 | 05:45 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
truth be told, it's a real pita. so is accessing the filter after the install. however, the gains are worth the initial frustration.
Old Jan 4, 2007 | 11:00 AM
BC Bob's Avatar
BC Bob
http://forums.corvetteforum.com/show...araram+install
Try this thread. I ended up removing the corregated rubber throttle body connector and bought a two 3" pieces of red silicone hose from Extreme PSI. The hose next to the TB increases from 3 7/8" to 4". The hose from the Vararam is 3 7/8" both ends.
Old Jan 4, 2007 | 11:08 AM
ShockerRacing's Avatar
ShockerRacing
Here is my install writeup:
http://www.shockerracing.com/phpBB2/...pic.php?t=1380
Old Jan 5, 2007 | 03:36 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by ShockerRacing
Great instuctions, used them myself a few months back, thanks. Cutting the shroud is a piece of cake. The install took me only minutes. Just don't extend the utility knife fully when you are at the top and cut the top last so you can see from the sides where your evaporator is and not cut it.
Also, if you cut the template where the dotted lines are it fits down on the nubs on the shroud and then the hole it makes is perfect.
Here's a pic of what I mean:
Old Jan 5, 2007 | 02:43 PM
ShockerRacing
Thanks Joe, I am glad they helped. I completely agree that the precut shroud is a waste of time and money. If the shroud is cut carefully and you put something behind it while you cut it there should be no issues!
Old Jan 5, 2007 | 03:46 PM
jjohn918's Avatar
jjohn918
I agree with the posts above. This is a true DIY mod. A little patience and planning will get this job done in a satisfactory amount of time for most people.
Old Jan 5, 2007 | 09:45 PM
PaulC6Z's Avatar
PaulC6Z
This thread is just what I wanted to ask. I'll put mine on this weekend.
Old Jan 5, 2007 | 11:16 PM
CONMAX's Avatar
CONMAX
Default vararam hood inteference
the install went ok on my 07 LS-2, but it touches the hood cover. i have the spacer which compounds the clearance problem. there is so much upward bias on the hoses that it forces contact with the hood cover. this could also eventually deform the fiberglass hood.
has anyone experienced this problem?
Old Jan 5, 2007 | 11:20 PM
chemten's Avatar
chemten
it is a common problem because of the length of the tube. i adjusted mine slightly to compensate. i actually don't have the mounting bracket flush with the front of the car. it is away from it so that the intake extends a little further towards the TB with the MAF. this helped a little since the natural bump of the hood is a little higher the closer it goes to the window.
i do have a little notch in my hood liner very slightly, but i don't notice any damage to the hood itself.
Old Jan 6, 2007 | 02:00 PM
OCCOMSRAZOR
It is a PITA, but I just loosened things up a bit and kept wiggiling everything until it eventually settled in below the hood.
Alot of pieces need to move just a little bit. Be patient and it will get there!
Old Jan 6, 2007 | 03:47 PM
GER42's Avatar
GER42
I agree. Cut your own but go slow.
I made a mess of cutting my shroud so I purchased a precut one. The whole thing fit better with my butcher job then it does with the precut one. I cut the crap out of the old one getting it out so I can't reuse it. Precut one doesn't seem to cut high enough. Too hot in the sun right now so I just threw it together. Next weekend I'll cut the precut one and make the whole thing fit better.
Old Jan 6, 2007 | 09:43 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Man it was hot today. What the heck is going on in January???
I think I kept my template and mine fits great. Let me know if you want it and I'll give it to you. And I used a new blade in a cheap blade knife and it cut very easy. Try a new blade if you didn't last time, it can make a big difference.
To Vararam install questions
Old Jan 7, 2007 | 01:50 PM
GER42's Avatar
GER42
I am now getting a check engine light. I wonder if they are related?
The first time the cutting was not the problem. I didn't cut high enough and had to keep trimming that's when I made a mess. I'm going to scribe a line and cut about an inch off. Might do it this afternoon but I'll have to make sure I drink a ton of water.
If it's this hot now what will the summer be like?
Old Jan 7, 2007 | 02:14 PM
chemten's Avatar
chemten
make sure you plugged all the censors back in when you replaced the shroud(i read above that you purchased a precut one). the MAF connector is all the way in and the temperature plug that is at the bottom, front right of the shroud. on my 07, there was another plug on that same side as the temperature one(not sure what that one does).
Old Jan 7, 2007 | 02:58 PM
GER42's Avatar
GER42
Thanks I'll check all the connections.
