Time for some heads!
Well, she's going back under the knife. I'm having so much fun with the N/A setup I'm going to stay N/A.
Currently waiting to be installed:
AFR 225cc heads milled to 63cc chamber
Using a .036 gasket to yield 11.5:1 CR
Underdrive pulley.
I have a Mamo ported FAST as well, but this won't be going on right away.
I should have numbers within 2 weeks.
Dougie
Can't go wrong with the AFR's though. Make sure you got a set with the good hardened valves, you know about that, right?
You coming up Friday to Moroso for the private test day? Those are a great time, pretty much pull up and run as many times as you want with no time pressure so you can get great logs. Also great time to get some video & pics of your car in the daylight.
