Cams for the C6
Old Jan 8, 2007 | 04:31 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Default Cams for the C6
Guys what is the best Cams for the C6 Vette? I need to know what's the best selling cams in the market. Please include Price and Horsepower.
Old Jan 8, 2007 | 04:42 PM
chemten's Avatar
chemten
cams are very customizable. a better question would be to ask yourself what do you expect from a cam swap? what kind of driving do you do?
Old Jan 8, 2007 | 04:56 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Sometimes aggressive driving.
P.S: I am welling to install the Cam for the "Light" drag racing :P, I aslo have LG Headers, Vara Ram Air Intake System (Snake Charmer), Diablo Predator, Stat and Borla Exh. System. And I want to complete the performance of my babe by installing the cam.
Old Jan 8, 2007 | 05:05 PM
chemten's Avatar
chemten
if you don't mind a rough idle, cams can get pretty aggressive to pump the HP up and shift the torque curve. i'd look at the forum vendors' websites and see what they can offer you. also look at head upgrades to go with your cam. this is a common combo upgrade(heads/cam) to do at the same time and further increase your benefit from the upgrade. if you don't upgrade the heads, you will most likely have to spend more on upgrading other parts to go with the cam instead of the heads.
Old Jan 8, 2007 | 05:17 PM
21STCENTURYMUSCLECAR's Avatar
Premium Supporting Vendor
Default C6 Camshaft
This is our most popular C6 cam and have made
490 RWHP with heads, LT headers and other bolt ons.
Cam is very streetable and makes great power throughout the power band.
Lingenfelter GT14 camshaft will produce excellent power and still have a streetable idle in six speed manual transmission equipped vehicles. Not recommended for automatic transmissions.
Suggested in 350-427 CID applications
Camshaft specifications: 228/232 duration @ .050 .590/.598 with 1.7 ratio rocker arms 113.0 CL.
IN STOCK $339.00 + Shipping
Best Regards,
John Page
Twenty First Century Muscle Casr
Authorized Lingenfelter Performance Dealer
Old Jan 8, 2007 | 08:02 PM
glennhl's Avatar
glennhl
Best Regards,
John Page
What do you recommend for a 2006 with the A6 auto and the stock converter?
Old Jan 8, 2007 | 08:08 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
what about this cam?
http://www.lgmotorsports.com/catalog...oducts_id=1509
Up to 70HP without the heads!!!! WooooooooooooooooooooooooW
Old Jan 8, 2007 | 08:15 PM
BADC64GO's Avatar
BADC64GO
Very good advice. A cam only gets you half there, cams and heads go together like exhaust and intake.
I would try a good tune with something like HPtuners on a dyno, then see if you want more.
Old Jan 8, 2007 | 10:05 PM
1vetteracer's Avatar
1vetteracer
The LG Motorsports cam is an excellent cam. Comp Cams makes these to LG's specifications. LG Motorsports provides excellent support and advice! Can't go wrong with these guys!
Old Jan 8, 2007 | 10:11 PM
Z-51 POWER's Avatar
Z-51 POWER
ohh yeah...I went with LG's G5X3 Cam and all can say is WOW, both performance and sound wise. Talk to Bobby or Anthony.
Regards,
Manuel
Old Jan 8, 2007 | 10:36 PM
Doug411's Avatar
Doug411
Just a quick thought. Isn't the cam adding 70 hp making too loud?
Old Jan 8, 2007 | 11:54 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
too loud of what..?
Old Jan 9, 2007 | 12:02 AM
Z-51 POWER's Avatar
Z-51 POWER
That loud to some is "music to my ears"
Manuel
Old Jan 9, 2007 | 01:31 PM
Doug411's Avatar
Doug411
Manuel
Exactly. I was going to say "too loud noise" but I just didn't put anything after "loud" because some think it's music. So, I meant loud whatever sound, drone or lope, noise or music, whatever.
So to what extent of lift the cam makes stock-like idling sound? .560? .590?
Old Jan 9, 2007 | 01:38 PM
chemten's Avatar
chemten
if you're talking about the exhaust idle sound, that is more affected by the lope of the cam rather than the lift.
Old Jan 9, 2007 | 01:44 PM
Doug411's Avatar
Doug411
Is that right? I didn't know that. I thought the lift makes exhaust sound louder because more lift means more fuel+air into the cylinder and more explosive chemical reaction.
What cams make most power with stock-like idle?
Old Jan 9, 2007 | 02:03 PM
xstang's Avatar
xstang
Doug I made 446 with this setup
Here is the idle
http://s53.photobucket.com/albums/g6...t=MOV00736.flv
1SX Z51
AFR 205s w/.040 cometic
Cheatr cam 215/232 117LSA
Honker Intake
Kooks
Shaner S3
Fast
3.90s
Custom tuning by Mark Shaner
Best 11.80 at 123.5 (20 HP ago)
To Cams for the C6
Old Jan 9, 2007 | 02:15 PM
chemten's Avatar
chemten
for a good example, listen to this: http://www.motorsporttech.com/media/..._idlesound.mpg
that cam is 224/220 .581/.581 116. 116 lope is the same as stock, but lifts are up at .581. sounds really close to stock idle and smooth.
someone please correct me if i am wrong in my reasoning for exhaust idle being controlled a lot by the lope.
Old Jan 9, 2007 | 02:27 PM
xstang's Avatar
xstang
Overlap... the more negative it is the less it lopes.... The closer to 0 overlap or positive overlap will lope more . To determine overlap:
Intake duration + Exhaust duration/2 - (2*LSA)
My cam 215 +232/2 = 223.5 223.5- 234 = -9.5
-9.5 = very little lope... -10 or more negative sounds close to stock...
Old Jan 9, 2007 | 02:32 PM
xstang's Avatar
xstang
That cam is -10 overlap... Very close to stock sounding
