How to increase low end torque without FI?
Without using any FI method (S/C, TT, N2O, etc), what would be the best way to increase low end torque on my C6/Z51 MZ6? I don't care much about top hp/torque and track numbers. Just want some more maggie-like power at 1500 - 3500 rpm.
Any thoughts?
Doug
Really want some exciting low end power. 4.10 gears. You'll be shifting a lot, but it's a hoot.
use a cam for that purpose. all of the strokers i've seen tested start with at least 35-40ft-lbs more torque at the bottom of the graph..
can't beat that w/o a power adder.
cheaper would be 4.10's with some lg headers..
a lot of people claim their xyz cam helped torque but, in all of the cars i've built/driven, none have made a small block a torque monster..
as for your comparisions, the h/c car will kill the other one from just about everywhere but, it will have "lightswitch" style power. by that i mean power will start at a higher rpm and pull further up the tach
to each his own. personally, i don't care for cars with cams. weird idle issues,ect.. i'd rather use 1.8 rockers and give up some top end hp
and use a set of afr 205's to help out the mid range.
I made up my mind to go with Maggie tens of times, because I want that low end torque. But whenever i see Mustangs and Camaros with high-rise hood, I couldn't pull the trigger. It's just not my style.
But I still don't know. I'm gonna decide before spring comes, I just can't decide which way to go - Z06, TT, Maggie, centri, H/C, 403/427... I just don't know because i have never driven one with any of them.
However, to make the gears work, you need Bilsteins to stop wheelhop and Nitto R2 / NT01 tires to put the power down off the line. I use 305 rears on custom-widened Y2K 18x9.5 rears (now 11 inch), which were done by James at Weldcraft wheels. This is the ultimate stealth cheatr setup.
Well, OK, there is NOS.
I have had 3 different blower engines, one of them a 4.3L V6 in an S-10. With no other mods, I had way more TQ at 1500 RPMs than most h/c V8s.
Best is to have a good tuner do his magic. A good tuner can tune the car( with current set up ) for a more flat torque curve then the stock tuning curve.
Bolt on are sexy, but a tune for $400 will get you closer to what you want then $2500+ in bolt ons
I would cam the car and add a comp cams adjustable timing chain and advance it enough to get to 8.7DCR for the best low end response coupled with 4.10's and headers. I've seen 400rwtq at 2200rpm.
Air cleaners and $1000-mufflers are a waste of money.
, and his setup is well tuned.
