I have the A6,lightly modded with Vararam,and soon to have Headers and B&B RT66 and tune.My ? is, will it benefit me to run DRs or not.I only bring the car to the track 1 or 2 times a year,Do you think there will be a big difference in timeslips?
If you're only going to go a couple of times a year then I wouldn't bother. I ran a 12.48 on Z51 runflats and there are others that have run quicker, LS1LT1(Mark). Mark is completely stock, or he was, and I have the Vararam. If you don't have the Z51 tires then maybe I'd look into DR's.
Tony,i dont have the Z51 tires,i have the 1lt base package.I was at kuhmo street warriors last year and ran in the 1/8 stock 8.883 at 83.06mph.My rt was .646 and the best without red lighting was .500,my 60 ft was 2.17 on the base tires.Since i have the Ram air,and soon to have cat bat , headers ,and tune was thinking i would lose alot of traction.
dennis50nj,did you us DRs to achieve your low times.Do you have tm?I know you have Vararam and other tuning and mods threw Cartek.
yes i went faster with the dr's. but i wet an 11.980 on the stock run flatts with a 1.791 60 ft some of the TM has been relaxed. i dont think you can get much out in the a6 yet even though some say you can havent seen any great 60 ft's as of yet
Were your runflats base or Z51 tires?What type of rim size and DR size did you use?Thanks
the 2.17 60 ft was TM. Marc has been 1.8s on the same tire as you after all mods i still could not spin tires on starting line. went 12os consistently. after converter i would just spin so i had to baby it of the line, and with drs it still spins have to leave at an idle 600rpm
yes it is a z51 1sb loaded the z51 tires work great. went with bfg 295 35s 18s and a aftermarket chrome rim 9.5 x 18 65 mm i got them from AutoWerxInc.com i went there the mounted balanced and switched sensors for about a thousand there near phila. the guy is a real pro. i leave them on and they wear as good as the runflats it handles better to
Thanks for the info.I am trying to beat that Kuhmo Vette.Last year they wanted me to run that Vette(C4),and it was running a consistent 7.9 to 8.1 and i new i was gonna get stomped wit my 8.83,so i passed on that one,but this is a NEW YEAR!
i know cartek is a long way from buffalo, but after the headers an tune i went from there shop to atco pulledin still hot didnt shut the car down drove to starting line and ran a 12.060 the 1/8 mile was 7.737 at 91.11 with the stock runflatts no converter so that should beat that c4 also i would think the a6 base model would be faster
See,thats what i am saying,i thought for sure my car would run at least 8.2 to 8.4 in the 1/8, and those times you had after the headers and tune is what i hope to have.Those are the times i am looking for(7.73@91mph)Thats awesome.
thanks. my last time at the track the 1/8 was 7.426 93.27 and the traction was bad 60 ft was down
I would just flip if i could attain the 7.7 let alone a 7.4 .See to me, most of your street racing is basically an 1/8 mile, unless your on the thruway,and with the times you have your gonna blow away just about all that step in your way .
Dennis,you sure make me want to make the trip to Cartek.I just maptoit.com and its 6 hour drive and about the same for Cows place.I dont know,boy i wish there was a great tuner closer.
Don't forget Dennis has a 3800 stall TC. Whole different animal than the stocker.
Take a friend to the track to watch your launch and see if you are spinning. If you are not spinning you don't need the DR's. Or if you are just spinning a little and you don't track that much it may not be worth the investment. It can get a little pricey to get DR's on this vehicle because of the 19 inch wheels.
hey GARY. i gave him the time without the converter
Ok, I was more referring to whether or not he may need DR's. I would guess with your TC you would spin the runflats pretty bad on a launch?? Am I right about that?
I am going with a higher stall when I have the money in the budget. But as you know I am already set up for traction.
I am guessing without TM the A6 probably could spin the runflats pretty good.
True. I've regularly cut sixty foots in the 1.88 - 1.91 range on the stock non Z51 runflats (300 treadwear rating versus 220 on the Z51 tires) on a prepped track...in stock/near stock trim (especially without a tune) I don't think ya need DRs with the A6.
If you are cutting a 1.791 60' and turning an ET of 11.980 there is a lot being left in the first 60'. Tires with dramatically drop your 60' and lower your ET.
Reason: mispelling
