Any Benefits Using DRs/A6
Old Jan 9, 2007 | 10:17 PM
dennis50nj's Avatar
dennis50nj
Originally Posted by shurite44
Ok, I was more referring to whether or not he may need DR's. I would guess with your TC you would spin the runflats pretty bad on a launch?? Am I right about that?
I am going with a higher stall when I have the money in the budget. But as you know I am already set up for traction.
I am guessing without TM the A6 probably could spin the runflats pretty good.
your right on about that.have to leave at idle or i can still spin the drs with the converter but before the converter i could not spin the runflatts at the track
Old Jan 9, 2007 | 10:19 PM
LS1LT1's Avatar
LS1LT1
Originally Posted by mvonada
If you are cutting a 1.791 60' and turning an ET of 11.980 there is a lot being left in the first 60'. Tires with dramatically drop your 60' and lower your ET.
You're right, and they did LOL...the addition of BFG DRs dropped his sixty foots down to the 1.6s and his ETs fell to the 11.6s along with 'em.
Old Jan 9, 2007 | 10:22 PM
shurite44's Avatar
shurite44
On most drag car set ups I would agree but not with the gearing in a C6.
Old Jan 9, 2007 | 10:24 PM
shurite44's Avatar
shurite44
I know, I had no problems with traction. I did the DR's more for future mod plans than for the HP I am running right now.
I think really all I still plan to do is change the rear gearing and a TC. But it is going to be a while, probably 08.
Old Jan 9, 2007 | 10:45 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Well i would like to say thanks to all of you and your input,and Thanks to Ranger for giving me the idea for this thread.
Old Jan 9, 2007 | 11:04 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Is TM active on the 6 speed cars as well? I was told by a well known tuner that it is only active on the autos. Can it be relaxed through LS1/2 edit. Where are the paramaters located?
Old Jan 9, 2007 | 11:32 PM
dennis50nj's Avatar
dennis50nj
on the m6 it can be eliminated, but not on the a6 that i have seen. not yet anyway
Old Jan 9, 2007 | 11:36 PM
dennis50nj's Avatar
dennis50nj
thats what we all say, you will keep going till you find the class you can win the most money and be comfortable with i like to be on the lowest dial and run them down, that way if there playing a game i can pass and hit the brake
Old Jan 9, 2007 | 11:39 PM
shurite44's Avatar
shurite44
True, there is a real advantage to being the fastest car in the class. For one your opponent always has the opportunity to red light first. I would say in the first round in stock that gives you a 15% advantage right there.
