Installing shift light without running wires to PCM
Old Jan 10, 2007 | 07:07 PM
PETESC6's Avatar
PETESC6
Default Installing shift light without running wires to PCM
Well I did this in my 02 Z06, there was a bundle of wires going up to the instrument cluster. One of the 3 white wires was the tach wire, I just confirmed with my corvette mechanic from the dealership that the SOLID PINK wires are the switched power source wires. So it sounds like you could at least wire the Ground and the switched power source wire for a raptor shift light under the driver side knee panel. Just wanted to know if anyone has found the tach wire under that same panel. When I took the knee panel off today I could see one whit wire going directly up to the instrument cluster, maybe I'll try and get a test light up in there to see what it does, just wanted to know if anyone has got to this before I have.
Thanks,
Peter
Old Jan 11, 2007 | 11:19 AM
ShockerRacing's Avatar
ShockerRacing
I don't know anyone who has found that wire and actually when I had posted up asking about the tach wire at the computer there was not much help to be found on this site. I did get the tach wire info in the PCM from Raptor, but I wired it to the PCM. Here is my write-up if it helps any:
http://www.shockerracing.com/phpBB2/viewtopic.php?t=960
