Changing Brake Pads
Old Apr 1, 2007 | 09:50 PM
Miaugi's Avatar
Miaugi
Originally Posted by willhaveC6
...haven't decided on what pads to put on yet but leaning towards Carbotechs...
Carbotechs rock!
Old Apr 1, 2007 | 11:46 PM
willhaveC6's Avatar
willhaveC6
Thanks for the data !!!!
Old Apr 2, 2007 | 08:08 AM
C5 XTC's Avatar
C5 XTC
Originally Posted by TCW
Or use a 6 inch C-clamp to compress the caliper pistons back into the caliper.
Tom
If you use this technique the caliper will easily slide away from the pads (caliper still bolted at the bottom). C5 XTC
Old Apr 2, 2007 | 08:38 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Give the 2 screwdriver trick a try next time. I promise you will love it and never touch the c clamp again! I learned it from, of all things, an article in Corvette Fever. Everyone I've shown it to never goes back. I push the pistons back in literally 10 seconds.
Old Apr 20, 2007 | 04:20 PM
tjfontaine's Avatar
tjfontaine
Many thanks to JoeG for these hints ... just did mine today ... I still was a little confused and accidentally removed the wrong bolt to start with! I have a copy of photos here to help out others.
Here is the way I applied the screwdriver trick mentioned -worked like a charm!!
Make sure to loosen the proper bolt - the one with the 15mm hex head and the locking nut shown here
I used a 15mm socket with an adjustable as shown here - worked like a charm
When you swing the caliper down (wiggle it a bit if you need to - it'll go) it will look like this - just slide out the old pads and slide in the new!
Old Apr 23, 2007 | 10:08 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Glad to help. That screwdriver trick is a real time saver. Wish I'd known that 25 years ago! Wow I'm getting old. Great pics, makes the thread.
Old Aug 17, 2007 | 01:13 AM
Wayne Enterprises's Avatar
Wayne Enterprises
Great pictures!
Old Aug 17, 2007 | 10:31 PM
tjfontaine's Avatar
tjfontaine
Originally Posted by dzhang
Great pictures!
Thanks Man ... I have been tapping into the work others on here have done and figured I need to start giving back when I can ... I know how much pictures really help a person understand things better ... it really can help augment the writeups ...
Old Aug 18, 2007 | 02:10 AM
WHT's Avatar
WHT
tjfontaine, a thanks from me too. Nice work.
Old Jul 3, 2008 | 03:39 PM
rhoward2's Avatar
rhoward2
Old Jul 4, 2008 | 12:06 AM
BigSlick's Avatar
BigSlick
... great info...thx to all...
Old Jul 6, 2008 | 11:28 PM
kev1n's Avatar
kev1n
I've found that having a breaker bar always helps for stubborn nuts, just food for thought
Old Oct 13, 2010 | 07:56 AM
  #33
67 fastback's Avatar
67 fastback
How do I prep the rotors, when changing pads? It's time for new pads and If I use other brand pads will it chatter if I do not turn the z-51 rotors?
Old Nov 5, 2010 | 10:20 PM
  #34
SimpleC6's Avatar
SimpleC6
Also interested in what you guys are doing for the stock rotors when putting new pads in? Take them somewhere to get machined? Sand them yourself? Just bed in the new pads well?
Thanks for the great thread by the way.
Old Nov 6, 2010 | 12:15 AM
  #35
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I've never surfaced the rotors. Just put on new pads and go. No problems, 48000 miles.
Old Mar 2, 2011 | 10:56 PM
  #36
SimpleC6's Avatar
SimpleC6
So does anyone actually replace those caliper retaining clips? My ACDelco pads came with a set of metal clips that say to replace the old ones. Is this necessary?
Thanks for the great pics!
Old Mar 24, 2011 | 10:30 AM
  #37
marathon's Avatar
marathon
St. Jude Donor '09
Does anyone know if this pad replacement procedure will work on GS brakes?
To Changing Brake Pads
Old Mar 24, 2011 | 11:24 AM
  #38
Dave S's Avatar
Dave S
Retired & lovin' it!
Many thanks to tjfontaine.....like the man says "A picture is worth a thousand words."! Getting ready to do a first pad swap this Spring & the pictures are invaluable.
Old Mar 24, 2011 | 11:29 AM
  #39
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I love this procedure! It's so easy and fast to swap pads using it.
I don't think this works on GS brakes as they are a fixed caliper so you can't slide it back on the pistons like you can a base or Z51. But I've not changed brakes on a GS or Z, only looked at the calipers so perhaps someone smarter than me will chime in.
Old Mar 24, 2011 | 12:51 PM
  #40
marathon's Avatar
marathon
St. Jude Donor '09
Thanks Joe, you are correct and I found a nice write up with photos in the Z forum.
