LSA Changes
Old Jan 12, 2007 | 10:13 AM
knkali's Avatar
knkali
Default LSA Changes
I know smaller LSA numbers usually mean rougher idle but what other effects are there?
Old Jan 12, 2007 | 10:56 AM
Buffy's Avatar
Buffy
Generally, a smaller LSA means a "peakier" cam - a narrower power band. Idle roughness is a function of the duration and the LSA. In fact, all of these numbers interact, its very hard to change just one and get a predictable result.
Old Jan 12, 2007 | 04:44 PM
knkali's Avatar
knkali
I realize many things are related but there must be some basic things one can expect with dif LSA cams with the same intake, exh, lift and duration
Old Jan 12, 2007 | 07:40 PM
Speed7's Avatar
Speed7
Default Lsa
Generaly speaking, you would improve mid range to high rpm performance at the expense of idle and low end.
Ron
Old Jan 12, 2007 | 08:06 PM
knkali's Avatar
knkali
so to make sure I have this correctly. Smaller LSA numbers make more power higher in the RPM range and larger LSA numbers make power lower in the rpm range?
Old Jan 12, 2007 | 10:57 PM
gtovan's Avatar
gtovan
Generalization: The larger LSA cam will have a flatter torque and hp curve with a slightly lower peak number, the lower LSA cam will have a steeper curve before and after peak is reached. Smaller LSA cams usually have a tighter intake centerline (earlier intake valve closing). This offers very good low rpm torque.
Having said that, LSA is not what you want to look at in choosing the valve events for a cam. Intake valve closing point, durations for the particular engine size and objective considering overlap, head flow at various lifts, the ratio between intake and exhaust flow are all much more important. LSA is just a number after getting these other events correct for your application.
Old Jan 12, 2007 | 11:32 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Good point - The key is in moving air in and out most efficiently.
Old Jan 13, 2007 | 12:49 AM
knkali's Avatar
knkali
All good info. I am learning thanks!
Old Jan 13, 2007 | 01:00 PM
Speed7's Avatar
Speed7
Default Cam events
I'm not going to get into an argument here, but some of what gtovan says above is correct but tighter lsa gives more overlap which produces rough idle which hurts low end torque. It is true that less angle closes the intake sooner which will give more torque, if you were comparing to alike cams. This can get real technical and I could get into a real argument here but I won't. I have built hundreds of racing engines and degreed hundreds of cams. I have built my own flow bench and have done extensive testing on single cylinder race kart engines. The principles are the same in multi cylinder engines. To quote Smokey Yunick, "A larger separation angle generally produces more low-end torque and a loss of top end power."
Later, Ron
To LSA Changes
