Couldn't pull away..! WTF!?
tune made all the difference in the world.. I still haven't used a wideband to calculate a/f at WOT and partial throttle but that'll be done sometime this weekend hopefully.. Still, I managed to zero out my LTFTs at WOT and knocked out knock.. Adjusted my TCM (although I still need to finetune my locking/unlocking speeds slightly).. Modified the timing table and changed some MAF settings.. TM is completely out now as opposed to reduced in yesterday's tune..
I've got so much to say but I'm tired and have work tomorrow,,
I'm looking forward to this weekend.. Planning on SD tunning the thing to get the VE table right and then I'll decide whether I'd wanna run mafless or not..
.. tonight I don't sleep disappointed
So, let's hear what happens if you two run again....
Lou and I tuned the GTO on LG's Dyno. He encouraged me to go as high as 30* I ended up around 25* in the heavy GTO.
In the case of my race I'd say that if you weigh factors against each other driver skill 1%, car tune 99%..
Xctasy - a cam is only going to yield maybe half its potential without a tune, timing, AFR, and your VE tables have got to be way-off until you get a tune, also a intake manifold is necessary to take full-advantage of cam.
Allow me further elaboration, and this is totally my opinion. I have had my fair share of trial and errors:
1) Tuning: Whenever you introduce a cam into a motor you are essentially changing the manner on which the car will behave...the whole package is now altered. A good tuning however, will/can make all the pieces come together but only if you or whomever had carefully chosen all the pieces. I've seen many people add a cam into a car and go slower; they may sound mean as hell but run worth a damn. If all your parts were chosen properly for your set up...ie TB, heads, intake and so on, then a good tuning can yield 20 to 30 additional rear wheel horses or more!
2) If I recall correctly, the Z51 C6 is lighter than your Automatic C6. Taking that into consideration, the package of that Z51 is such that it works around it’s given components. In other words, the whole thing was designed to maximize and complement what’s there (suspension, braking and power band due to gearing). Your friend essentially improved the already decently stout stock set up by adding headers (better exhaust flow) and CAI (better breathing capabilities).
3) Gearing plays a huge role. Remember, he has 3.42 gears PLUS his trans is geared to totally take advantage of the giving powerband of the LS2 mill with stock heads and cam. Great trans gearing was one of the C5 Z06’s advantages over the C5 coupes, Verts and FRC's.
Your improvement of let's say 30 to 40 rear wheel HP from stock will roughly net you about 2 to 2.5 tenth AND possibly 1.5 to 2.0 mph gain in the 1/4 mile considering your current weight and choice of transmission. By the sound of your set up, I believe that you really need a properly stalled torque converter to take full advantage of the new cam. Remember, if everything being equal (traction/power and driver) automatics really has an advantage over sticks from a stand still. Your particular combo vs his from a rolling start is not a big advantage right now over his better geared rear end and trans, lighter chassis and possibly better tuned Vette. Now, once you get that bad boy tuned and do something about that converter, you will smoke him from any point (rolling or standing start).
Replacing gears is a good idea, but if I were you, I would do Converter before a rear gears. The cost of gears and a torque converter I believe is about the same. Torque converters are typically good for at least a 0.3 tenth in ET reduction and it will compliment your new cam a little better than the gears at this point. In fact, a converter will "wake up" that semi-sleeping beast!
Again, this is just my opinion and this is what I've seen work on automatic C5's, 5.0's, Fbody's and also GN's.
