Transmission Shift kit for A4?
Old Jan 15, 2007 | 10:52 AM
landry2756's Avatar
landry2756
Default Transmission Shift kit for A4?
Does anyone know of a "shift kit" or a Mod for the A4 automatic transmission? I would like a firmer, quicker shift is possible with this transmission.
Old Jan 15, 2007 | 11:00 AM
xtacy187's Avatar
xtacy187
The shift-kit TransGo makes for the 4L60e should work perfectly with your A4 automattic assuming you still use the stock A4 C6 trans (4L65e)..
Old Jan 15, 2007 | 11:22 AM
backinblackC6's Avatar
backinblackC6
Get a tune !!!! Mail order from CoW will work great, it did for mine. Shifts are strong and fast...
Old Jan 15, 2007 | 07:10 PM
mo-shy's Avatar
mo-shy
Old Jan 16, 2007 | 06:42 PM
landry2756's Avatar
landry2756
Will this computer tune up replace the shift kit? Or get both of them?
Old Jan 16, 2007 | 08:31 PM
C6Rluvur's Avatar
C6Rluvur
The only problems w/after market tunes for firming up shift points, is it actually can make the car dramatically slower, real experience here on my 2005 A4 C6, tuner shall remain un-named, tuned the trans & car in general,..
Felt awesome, kicked down to gears really quick giving a no lag shift pattern stepping on the gas meant instant downshift felt great, here's where it sucks!!!
I ran a buddy who owns a Mercedes E55 w/Supercharger, on closed old runway strip, we've ran the 2 cars 30 + times w/my C6 always beating his by 3+ car lengths, directly after tune, we raced same place, same conditions, same cars, exact, except for my new tune, C6 felt like a runner, we lined up, my buddy's E55 beat me everywhere down low, up top!!! I lost by 5 plus lengths from a dig!!!! before I'd win by 3+,
then on a roll same thing me losing by multiple lengths, I was pissed!!
Took the C6 back had it re-flashed to stock, we ran again same day, now I beat him again back like I used to?? we even traded cars before & after to make sure there was no driver differences, none what so ever..
Summation, although the tune makes the car behave like a beast, slamming thru the gears, I believe the re-mappedd shift tune doesn't hold you in the power band long enough in each gear, making you loose by short shifting to fast, I don't think my tuner was the problem, he's from a very well known Vette shop here on the boards, dyno tuned, and road tuned my C6..
I think the factory shift points are set optimally for perf, and re-mapping them just screws you up, unless you like feeling like your fast but in reality extremely slower...The only answer in my book is mod for more HP, or better yet get 3.90's from COW
Yes COW's trans tuning is needed w/new gears, but I'm sure only to reset rpm levels, not necessary to firm up shift patterns..
Take it for what it's worth just my personal experience, maybe yours will vary...
Old Jan 16, 2007 | 10:11 PM
landry2756's Avatar
landry2756
So it sounds like to me I would be better off just getting a shift kit to make the shifts firmer and quicker with less slippage? Hopefully by leaving the computer alone on the shifting, it won't slow me down on ultimate performance...... I would like to have a computer tune-up if it would make the engine run better with more torque in the lower part of the power band without losing overall performance....I would like to put some headers on it at some point, maybe I should wait until I do that before tuning the computer? Do you have an opinion on the best headers for the money?
Old Jan 16, 2007 | 10:52 PM
backinblackC6
Give Chuck at CoW a call. He has built the A4 transmission for years. He can guide you in the right direction.
As for the car getting slower after the tune, I guess it is possible and the former thread is proof of that. Mabye he had a bad tune, but from what I have read on the forum, a tune is the way to go without having to open your tranny and some of the posts have 1/4 mile times to prove it helps.
Good luck in your decision. IMO..Get all the info you can before opening that tranny.
Check out the thread...just a tune worth it....in this section.
Old Jan 17, 2007 | 12:36 AM
Red903L's Avatar
Red903L
Had mine dyno-tuned and during the session, the technician adjusted the transmission shift points and it shifts FAST & POSITIVE now! The really great thing about getting it tuned in this manner, is that the operator can make other adjustments that will make your car run great!
Such as.... he reset the temperature the engine cooling fans cut in so the engine doesn't get so hot before they finally come on..
The real KICKER was when he leaned out the fuel mixture, which is set overly rich from the factory, and he tweaked the timing a couple degrees. These two "tweaks" resulted the RWHP going from 299hp to 312hp and a Torque increase from 307.2 to 327..
A good dyno tune can run around $500, but the results are pretty impressive.
JUST MAKE SURE YOU GO TO SOMEONE WHO KNOWS WHAT THEY'RE DOIN'..........
Good Luck....
Old Jan 17, 2007 | 11:56 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Shift Kit
Yes, There are afew shift kits for the A4 trans and they are a great idea.
But, do not get one if the installer is not VERY familiar with the trans and Vettes....
ALSO, if you are thinking of a tune AND a shift kit....Then, there are many things to consider as some of the benefits of each will overlap causing undesired results if the tuner/kit installer are not cordinated.
The trans tuning I do WILL NOT slow down the car......Speak to anyone I have done this for... it is a MASSIVE improvment in shift feel, trans durability, and overall performance. You will love it!
The A4 trans is a SLUG in stock trim and with a stock tune. I have been building 700's and 4L60's for nearly 20 years and more recently, I've come up with a really HOT tune for the later units and believe me, I can make that baby sing!
I can tune the trans in person or by MAIL ORDER TUNE and either way you won't believe what that trans can really do when it's set up properly!
I love A4 cars!
Chuck CoW
Old Jan 17, 2007 | 05:51 PM
C6Rluvur's Avatar
C6Rluvur
I love A4 cars!
Chuck CoW
I know you allready have enough business but...I've been burned before w/full dyno/street/trans-tune, I'll buy your mail order tune If after I try racing my friend again and it indeed performs better, I'll keep it, if not can I send it back for a free stock reflash and money back w/promise not to write about it if it doesn't work out for me? as you can see I don't bad mouth tuners by name?
You can reply in pm if you feel privacy is necessary...
Old Jan 17, 2007 | 06:28 PM
dennis50nj's Avatar
dennis50nj
Old Jan 17, 2007 | 06:37 PM
Radical05's Avatar
Radical05
Default Get a Tune
To each his/her own but I had my car eng/trans computers tuned while on the dyno at Next Level Performance and wow what a difference. Mail order may be ok but the car there in person is best I don't care what anyone says. My 05/A4 is far better and I did not tune mine to the gills risking damage. If it were on a scale 100% being maxed out I'm probably 90%. It hits second around 50 or so and better hold on for smoking tires and rear end swings. Even more noticeable if you pull it down in L and shift it yourself. Pretty close to how a stick acts. That's my 2c and experience.
Old Jan 21, 2007 | 01:15 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default No need to keep it private.....
Hey there.....
No need to keep it private...I've done this 1,000 times and I am not shy....
If you don't like the way it feels or performs I'll gladly put it back to stock and return your money to you...That has always been my guarantee.....
A4 cars are tons of fun if you tune 'em right.....Contact me and I'll tell you more about it.....
You will love it!
Chuck CoW
Old Jan 21, 2007 | 06:39 PM
C6Rluvur's Avatar
C6Rluvur
Default Excellent!!
Hey there.....
You will love it!
Chuck CoW
I'll be contacting you soon.. thanks for the reply...
Old Jan 25, 2007 | 08:08 PM
Chuck01's Avatar
Chuck01
Please keep us updated. I have only heard of GREAT things from Chuck.
Old Jan 25, 2007 | 10:45 PM
Radical05's Avatar
Radical05
Default tune
Recommend a tune/dyno and then drive and see for yourself the difference.
Old Aug 3, 2022 | 11:55 AM
C6moblife's Avatar
C6moblife
Yes, There are a few shift kits for the A4 trans and they are a great idea.
ALSO, if you are thinking of a tune AND a shift kit....Then, there are many things to consider as some of the benefits of each will overlap causing undesired results if the tuner/kit installer are not coordinated.
The trans tuning I do WILL NOT slow down the car......Speak to anyone I have done this for... it is a MASSIVE improvement in shift feel, trans durability, and overall performance. You will love it!
I love A4 cars!
Chuck CoW
whats the cost? and whats the mail order options, seeing how im in CA. thanks chuck
Old Aug 4, 2022 | 09:38 AM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Lolol. 15 year old thread.
Cow hasn’t been on this forum for years. And I wouldn’t recommend him to work on my big wheel.
To Transmission Shift kit for A4?
