diff fluid
Old Jan 15, 2007 | 11:31 AM
IC6's Avatar
IC6
Default diff fluid
thinking of changing out my diff fluid for some aftermarket/synthetic to avoid going to the dealer (i have some chatter)
what brand/types have you used?
and what additive brand/type do i need?
how much of each?
i guess i need something to keep me occupied during the winter, going crazy need some nice weather so i can start driving it again...
Old Jan 15, 2007 | 12:11 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I changed mine with Royal Purple MaxGear. No additive needed, it's in there.
Old Jan 15, 2007 | 01:02 PM
hbvette07's Avatar
hbvette07
I have read Mobil 1 75W-90 works well. I have not tried it yet but plan on changing out the trans and the diff soon.
Old Jan 15, 2007 | 04:51 PM
GOOG's C6's Avatar
GOOG's C6
Member go to the dealer at NO COST!!!! There is a TSB on the issue and the remedy is to replace with a synthetic . So, you are getting what you want and the dealer has to eat it. Might as well enjoy the molment, there won't be too many opportunities to take advantage of a dealership at there expense . Especially if you own a vette.
Old Jan 15, 2007 | 05:06 PM
Buffy's Avatar
Buffy
I've been using the Mobil 1. With most of the synthetic fluids you have a choice of using additive or not. I think some of this is just personal preference - how tight do you want it to be?
Red Line recommends trying it without, then adding just enough to get it the way you want it. Makes sense to me.
Old Jan 15, 2007 | 05:46 PM
hbvette07's Avatar
hbvette07
You know it just may be past experience but, I try to avoid the dealership. I will either do it myself or pay a little more to have a mechanic I trust to do it. Just my .02
Old Jan 15, 2007 | 06:51 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
We use RedLine 75w90 in every HP build, and every single one of our World Challenge cars. One of the best oils on the market to date!
Old Jan 15, 2007 | 07:21 PM
VET4LES's Avatar
VET4LES
Old Jan 15, 2007 | 08:41 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
The additive you want is GM part number 1052358 Limited Slip Differential Additive. At 1bout 1500 miles, both FXB3 and I drained our differentials (no symptoms in either one) and put in Mobil 1 synthetic 75W-90 axle lube plus the GM additive. Then we did a couple of dozen slow "figure 8's" in the parking lot to work the additive in between the clutch plates.
If you have symptoms, let the dealer do this for you at GM's expense.
Old Jan 16, 2007 | 09:28 AM
Bandit1's Avatar
Bandit1
AMSOIL
Old Jan 16, 2007 | 09:34 AM
IC6's Avatar
IC6
my thoughts exactly.
Old Jan 16, 2007 | 10:44 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Applicable AMSOIL diff fluid:
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90
This fluid comes with the friction modifier in it and you should not need additional modifier, though AMSOIL does carry the product: AMSOIL Slip-Lock Differential Additive
The diff will take about 1.7 quarts so you'll need 2 quarts of whatever you decide to use.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jan 18, 2007 | 07:14 PM
LEAVINU's Avatar
LEAVINU
Looking at using the Royal Purple Max Gear. I found some at a local shop here in GA and noticed it is a 75W 140 weight gear oil. I see Anthony from LG recommended the Redline which is a 75W 90 gear oil.
Whats the difference b/t the two gear weights?
Thanks.
Old Jan 19, 2007 | 12:44 AM
C66 Racing's Avatar
C66 Racing
Essentially the viscosity. Using the AMSOIL's 75w90 and 75w140 viscosities as an example since I have those handy, the 75w90's viscosity at 100C (212F) is 16.4 and at 40C (100F) it is 108.79 cSt. The 75w140 is 25.7 at 100C and 185.6 at 40C. Essentially the 75w140 is heavier. This will provide better protection at elevated temps, but it will cause additional friction and heat at lower temps. GM recommends 75w90 in the stock diff and that's what I've been using on the track for years and have not had any diff failures other than a failed left axle seal which is a common C5 Z06 problem.
To diff fluid
